Yes, you can have a separate server as CA for EAP-TLS client (and server as well) certificates. In fact, I think there even is a recommendation to run the Microsoft AD Certificate Services on a member server, not on the AD; but the integration with Active Directory and Group Policies is a benefit.
When you move to Entra ID, you probably will use a different CA anyway, so yes it's possible. But what would be the CA that you are looking to work with? In that CA documentation you may find guidance how to integrate with AD (if you want to).
From a ClearPass perspective, it doesn't care which CA issued the client certificates as long as that CA is added and enabled to the Trust List for the 'EAP' type. If the AD username, or other AD identifying attribute is missing in the certificate, you can even disable authorization and just authenticate based on the certificate only (no AD check).
But your question is too broad to provide a full answer as it's not clear what you try to do, or what is the ultimate goal, in enough detail.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: May 06, 2025 06:39 PM
Subject: Separate CA Server other than AD, is it possible for EAP-TLS, Clearpass
Hi Everyone,
I hope this message finds you well.
Is it possible for EAP-TLS method that you have a separate Certificate Authority (CA) server other than AD? if yes, can you help me for the references on how to integrate this one, what are the limitations of using this and need to be consider using this set-up?
Thank you
