Seperate SSIds
  • 1.  Seperate SSIds
    Posted Nov 18, 2023 06:17 PM
    Hi Community
    Kindly advise me to create TWO separate SSIDs for 2.4 GHz & 5.0 GHz bands or a single SSID for both bands. Whose performance will be better?. I have two Cluster One is based on IAP  515  consisting of 50 APs. The second cluster is based on IAP 207 consisting of 26 APs.. Both clusters are separate and in different  Hostel buildings.
    Samir. S
    Samir Srivastava
    KNIT Sultanpur (UP)
    INDIA
  • 2.  RE: Seperate SSIds
    Posted Nov 18, 2023 07:39 PM
    These days, all you need to to configure a WLAN for both bands, that i also the default setting.
  • 3.  RE: Seperate SSIds
    Posted Nov 20, 2023 02:40 PM
    In general if you deploy a dual band ESSID on 2.4 + 5 GHz, modern clients will prefer connectivity to 5 GHz. To force connectivity to 5 GHz on the infrastructure side, only allow 5 GHz on the SSID. Performance will likely be better on 5 GHz and may be able to use 40 MHz wide channels in 5 GHz, but of course depending on what else is using the local RF environment.
    Josh
  • 4.  RE: Seperate SSIds
    Posted Nov 22, 2023 06:41 AM
    Thanks Dear
    Dr.Samir Srivastava
    Associate Professor & Ex Head
    Computer Science & Engg, Department
    Kamla Nehru Institute of Technology,
    SULTANPUR (UP)  228118
    INDIA
    Mobile : 9415077351   &   7007474344
    Disclaimer:
    Messages from 'knit.ac.in' mail server and any associated files may contain information that is confidential, subject to copyright or contains proprietary information. If you are not the intended addressee you are hereby notified that any dissemination, copying or distribution of these messages, or files associated with these messages is prohibited. If you have received the message in error, please notify us by replying to the concerned message and deleting it from your computer. Please also scan the message to verify that it is virus free. Thank you for your time.
    This email is governed by the Disclaimer Terms of  KNIT.
  • 5.  RE: Seperate SSIds
    Posted Nov 22, 2023 12:06 PM
    It is preferable in most cases to use a single SSID. "Performance" is subjective, as 2.4 GHz provides more than adequate speed and has much greater range. A single SSID permits clients and the AP to use the best band.
  • 6.  RE: Seperate SSIds
    Posted Nov 22, 2023 12:30 PM
    Kevin,
    In general, 5 GHz will offer better performance (and even coverage area) than 2.4 GHz when deployed and configured correctly and has a lot more available channels that can be reused more effectively and even bonded for greater channel bandwidth (there is no opportunity to bond channels in 2.4 GHz).
    2.4 GHz is often congested with high utilization (duty cycle) in most environments resulting in a lot of upfront contention in order to Tx. 2.4 GHz has fewer channels (3 or 4 depending on regulatory and how you prefer to slice it, most stick to 3) compared to 5 GHz for effective reuse. 2.4 GHz should be considered a best-effort band for most use cases. If 2.4 GHz was more than adequate, Aruba would not offer multi-band APs with 5 GHz and 6 GHz radios.
    Josh
  • 7.  RE: Seperate SSIds
    Posted Nov 22, 2023 12:42 PM
    Josh,
    My experience in and around block structures is 2.4 GHz offers far better penetration through brick and steel.
