  • 1.  Seperate SSIDs per 5GHz radio in Tri-radio mode
    Posted Jul 11, 2021 10:56 PM
    Is it possible to specify which 5GHz radio services which SSIDs on an IAP-555? For example, Radio 0 has SSID-A and SSID-B, while Radio 1 only has SSID-C.
  • 2.  RE: Seperate SSIDs per 5GHz radio in Tri-radio mode
    Posted Jul 12, 2021 09:02 AM
    I do not believe so.
    Dustin Burns
    Senior Mobility and Access Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: Seperate SSIDs per 5GHz radio in Tri-radio mode
    Posted Jul 12, 2021 05:28 PM
    Shame as I think it would be good a feature to help priorities certain users
  • 4.  RE: Seperate SSIDs per 5GHz radio in Tri-radio mode
    Posted Jul 12, 2021 07:51 PM
    currently it is not support for Instant APs, but it is on controller based deployment
  • 5.  RE: Seperate SSIDs per 5GHz radio in Tri-radio mode
    Posted Jul 14, 2021 01:23 AM
    Interesting... Do you know if Central supports this?
  • 6.  RE: Seperate SSIDs per 5GHz radio in Tri-radio mode
    Posted Jul 14, 2021 03:47 AM
    not that i can see.
