Skip main navigation (Press Enter).
Log in
Toggle navigation
Search Options
Log in
Home
Discussion Forum
Support
Aruba Documentation Portal
Aruba Support Knowledge Base
HPE Networking Support Portal
Live + Virtual Events
Webinar Archive
Upcoming Events
News
Technical Blog
ACEX Hall of Fame
MVP Program
Become a Member
Search Options
Community Home
Discussion
122K
Members
3.3K
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
Serial Cable
Dale Severin
Oct 10, 2003 06:45 AM
What kind of serial cable and configuration is needed to connect a PC with a DB-9-port to the DTC with ...
Michael Steele_2
Oct 10, 2003 07:16 AM
Need the model number for the "...DTC with eight DB-25-ports...". Regarding "...what MPE-IX instructions ...
Dave La Mar
Oct 10, 2003 02:39 PM
Dale - You take me back to my CE days and I connot remember the actual number of active pins, but most ...
1.
Serial Cable
0
Kudos
Dale Severin
Posted Oct 10, 2003 06:45 AM
Reply Privately
Options Dropdown
What kind of serial cable and configuration is needed to connect a PC with a DB-9-port to the DTC with eight DB-25-ports. Also what MPE-IX instructions are necessary for the HP3000 to acknowledge the PC as a terminal.
2.
RE: Serial Cable
0
Kudos
Michael Steele_2
Posted Oct 10, 2003 07:16 AM
Reply Privately
Options Dropdown
Regarding "...what MPE-IX instructions are necessary for the HP3000..."
This is a HP-UX forum for HP 9000 servers.
3.
RE: Serial Cable
0
Kudos
Dave La Mar
Posted Oct 10, 2003 02:39 PM
Reply Privately
Options Dropdown
Dale -
You take me back to my CE days and I connot remember the actual number of active pins, but most are common thus the market for the db9 to db45 converters. This are a shelf item in many retail stores. In the "old days" we would cut the end off and re-pin to the correct connector.
Best of luck.
dl
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Related Content
HP DTC Manager/UX
Raymond Carr
Added Apr 22, 2004
Discussion Thread
2
USB to serial (db9)
MSPA
Added Jun 08, 2012
Discussion Thread
6
DTC serial number
Archive User
Added Dec 15, 2004
Discussion Thread
3
bridging non-routable DTC to MPE over frame relay
paul rooney_1
Added Oct 14, 2002
Discussion Thread
3
PoE-powered media converter?
t3rb335t
Added Aug 01, 2014
Discussion Thread
11
Copyright 2024. All rights reserved.
Powered by Higher Logic
