  • 1.  Servie selection based upon ssid
    Posted Nov 30, 2021 05:53 AM
    Hi All,
    Quick question,  When creating  a cppm service specific to a given SSID, up till now i've been using the Radius:Aruba  SSID attribute  (Aruba-ESSID-Name)  to "tie" a service to an ssid.
    Given that  you can also use Connection / SSID/ equals ........
    Why use one over the other ... other than not using Aruba wifi kit ?
    Rgds
    Alex
    Alex Sharaz
  • 2.  RE: Servie selection based upon ssid
    Posted Nov 30, 2021 07:41 AM
    I didn't know the Connection:SSID existed. Would not know why to use one or the other... there are more things in ClearPass that you can do in multiple ways.
  • 3.  RE: Servie selection based upon ssid
    Posted Dec 01, 2021 03:53 AM
    Yes I agree, always multiple ways to do the same thing - don't believe there is a right and wrong way.
    In this instance we've always used standard Radius - Called-station-id - contains "SSID" - That's obviously if your solution is including the SSID in the Called Station ID - which is often an additional setting.
  • 4.  RE: Servie selection based upon ssid
    Posted Dec 01, 2021 09:04 AM
    o.k. another way :-)
    We have that option to append the SSID to the casing station id disabled
    Forgot about that
    A
  • 5.  RE: Servie selection based upon ssid
    Posted Dec 01, 2021 08:19 PM
    Connection:SSID is derived and works regardless of vendor (assuming the vendor sends the SSID in CSID or a VSA)
    Tim C
  • 6.  RE: Servie selection based upon ssid
    Posted Dec 02, 2021 03:20 AM
    Thats what I assumed :-)
