  • 1.  Setting a master controller and static ip for each AP via CLI
    Posted Aug 29, 2024 10:55 AM
    Hello Experts,
    Is there a an equivalent CLI command to set the 'Master' Controller and Static IP addresses to APs once they are approved in the allowlist?
    It is time consuming to go the the AP>Campus List GUI and manually input the information.
    Alex
  • 2.  RE: Setting a master controller and static ip for each AP via CLI
    Posted Aug 29, 2024 11:43 AM
    Why are you setting static discovery rather than dynamic?
    Use DHCP or DNS discovery, make life easier, not harder.
    The settings you are looking at are part of the AP provisioning, you can provision APs via the CLI but have to do that one AP at a time still.
    https://www.arubanetworks.com/techdocs/CLI-Bank/Content/aos8/prov-ap.htm
    Carson Hulcher, ACEX#110
  • 3.  RE: Setting a master controller and static ip for each AP via CLI
    Posted Aug 30, 2024 04:38 AM
    As Carson always says, you don't have to do this just because it's possible.
    I can also recommend that you don't use static IP addresses. Controller Layer 3 Discovery (with DHCP or DNS) and AP with DHCP addresses is really the better way. That way you stay flexible and changing IP addresses later is no problem at all.
    Waldemar
    ACCX # 1377, ACEP, ACX - Network Security
