Setting SSID to 5GHz only
  • 1.  Setting SSID to 5GHz only
    Posted Aug 14, 2020 02:52 PM
    I'm having trouble finding the spot where I configure a certain SSID to be 5Ghz only.
    This is with a Mobility Controller.
    Any suggestions?
    Thank you,
  • 2.  RE: Setting SSID to 5GHz only
    Posted Aug 14, 2020 03:43 PM
    Hi!
    Check this.
  • 3.  RE: Setting SSID to 5GHz only
    Posted Aug 14, 2020 06:40 PM
    I'm working with 8.4.0.2
    Just can't find the spot.
  • 4.  RE: Setting SSID to 5GHz only
    Posted Aug 15, 2020 03:28 AM
    Hi!
    Go to:
    Configuration > System > Profiles > Wireless LAN > Virtual AP > YourVAP > RF
    and choose your band.
    Basically it is the same as under 6.4 / 6.5 but the profiles menu moved to configuration - system.
    You also can click on your user name (right hand side on the top) go to preferences and select advanced view (or like that).
    Now you should also see a profiles link on the right side of the AOS 8 style config menus.
    If you operate a Mobility Master deployment, change this setting under the managed network node.
