  • 1.  Setting up Beoplay streaming
    Posted Mar 01, 2017 03:18 AM
    Hi, I found that in order to get my new Beoplay M5 to work streaming music I had to enable the AirGroup Service "allowall" which in turn means a number of new services is showing up (please see attached picture with Service IDs). My question now is: should I create a new AirGroup Service and include the Service IDs listet and then close "allowall" again; as I assume any other devices can right now create services that I might not be too interested in supporting? Will I simply have to type the lines and no further attributes?
  • 2.  RE: Setting up Beoplay streaming
    Posted Mar 01, 2017 06:39 AM
    You might have disable "allowall" service and  "show airgroup blocked-queries" (http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#CLI_commands/show_airgroup_cppm_entries.htm) on the commandline to see what Beoplay uses.  You would then create a new service that has the Beoplay blocked query.  It is typically "okay" to enable "allowall" as a test to troubleshoot, but it could create performance issues in a busy network in the future.
  • 3.  RE: Setting up Beoplay streaming
    Posted Jul 16, 2018 05:17 AM
    Would you care to share te sevices you needed to enable to allow Bweoplay to work?
    Rgds
    Alex
  • 4.  RE: Setting up Beoplay streaming
    Posted Jul 16, 2018 08:10 AM
    Hi Alex,
    As described earlier I enabled “allowall” and then moved the new services into a new group of Airgroup Services named “beoplay”. Please see attached photos. Works fine with Apple and TuneIn as I have enabled “iTunes” and “airplay” as well.
    AA604E21-B54A-4F44-A505-6E9F3FAD9F1F.jpeg234DAB72-F2F7-4B0A-8ACB-884B4892725A.jpeg828B5990-29AA-40FF-BD4F-EAF1833A167A.jpeg4AACD5C9-2349-4920-BD05-1DE0E18255EF.jpeg0A3CF746-1098-459D-8EF8-F264C9BEB441.jpeg
    kind regards, Torben
  • 5.  RE: Setting up Beoplay streaming
    Posted Jul 16, 2018 08:14 AM
    Agree, idear when creating “Beoplay” as an Airgroup Service was to disable again “allowall” as this might hit performance / security.
