Wired Intelligent Edge
Setting up SNMPv3 on 2530
Jump to Best Answer
  • 1.  Setting up SNMPv3 on 2530
    Posted Jun 28, 2022 11:37 AM
    Hi Guys,
    I have followed Document - 16.10 Aruba 2530 Management and Configuration Guide for ArubaOS-Switch 16.10 | HPE Support to setup SNMPv3 but I am getting "Security access violation from xx.x.x.xxx for the community name or user name : " whenever I setup our Management software (Forescout) to connect to it.
    When I use v2C it works
    I have added the forescout server as a trap server.
    The only difference I can see is that Forescout uses HMAC-MD5 instead of just MD5.
    Cheers
  • 2.  RE: Setting up SNMPv3 on 2530
    Posted Jun 28, 2022 03:55 PM
    Hey, I'm fairly new myself but maybe I can help out.
    1. Is snmp V2C still running alongside V3? If so, maybe try disabling it.
    switch(config)# snmpv3 only
    2. I assume you created a snmpv3 user for this application. Make sure it is part of the manager group.
    switch(config)# snmpv3 group managerpriv [username] sec-model ver3
  • 3.  RE: Setting up SNMPv3 on 2530
    Posted Jun 29, 2022 02:02 AM
    I guess that the SNMP query of your tool tries to connect with another community name. SNMPv3 only is not really necessary.
    What does your configuration look like?
    Example:
    snmpv3 engineid "xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
    snmpv3 enable
    snmpv3 group managerpriv user "TestUser" sec-model ver3
    snmpv3 user "TestUser" auth sha "xxxxxxxxxxxxx" priv aes "xxxxxxxxxxxxxxx"​
    Cheers
  • 4.  RE: Setting up SNMPv3 on 2530
    Posted Jun 29, 2022 03:44 AM
    Hi guys,
    Thanks for coming back. I actually resolved it prior to the post being approved.
    I started again with the settings and also removed and started the settings in Forescout. All working.
    Many thanks for your help.
    Cheers
