Original Message:
Sent: May 06, 2025 02:53 AM
Subject: Setting VLAN on HPE 5140 via RADIUS
VLAN30 would be Untagged.
If you refer to pushing multiple VLANs on the same port, i am afraid that you can't push a RADIUS Attribute forcing the port to be Trunk and permitting multiple VLANS as tagged.
Shpat | ACEP | ACMP | ACCP | ACDP
Just an Aruba enthusiast and contributor by cases
If you find my comment helpful, KUDOS are appreciated.
Original Message:
Sent: May 06, 2025 02:45 AM
Hmm... just wondering... If I want to tag other VLANs on that specific Port, how would I do that?
In your example, the VLAN30 would be Untagged on that Port, wouldn't it?
Regards, Thorsten
Original Message:
Sent: May 06, 2025 01:46 AM
I think the RADIUS Handling messages between Comware and AOS/AOS-X are different. Comware typically supports:
Tunnel-Type (IETF, Attr 64) = VLAN (value 13)
Tunnel-Medium-Type (IETF, Attr 65) = 802 (value 6)
Tunnel-Private-Group-ID (IETF, Attr 81) = <VLAN-ID or VLAN Name>
as an example:
Tunnel-Type = VLAN,
Tunnel-Medium-Type = IEEE-802,
Tunnel-Private-Group-ID = "30"
This would put you to VLAN30
Original Message:
Sent: May 05, 2025 05:21 AM
Hi Forum,
I want to set a Port on a HPE 5140 COMWARE Switch via RADIUS after successful authentication via MAB or dot1x (MACMON NAC).
I got this working for AOS and AOS-X Switches (Vendor-ID 11, Attribute-ID 64 / 65, "HP-Egress-VLANID" / "HP-Egress-VLAN-Name").
But I don't get it running for COMWARE.
I tried the same Vendor-Specific Attribute-IDs and the IETF Attributes EGRESS-VLANID / EGRESS-VLAN-NAME, but no luck.
A difference I recognized is, that for AOS I need to set another Vendor-Specific Attribut (Vendor-ID 11, Attribute-ID 14, "HP-MA-Port-Mode").
I didn't find anything similiar in the 3com/H3C/Huawei Vendor-Dictionary (exept for 3com' Attribute-ID2, "3Com-VLAN-Name").
What am I missing? Has anybody an idea or a hint to get this running?
Thanks in advance for any piece of information!
Regards, Thorsten
