Comware
  • 1.  SFP+ Direct Attach 10G cables
    Posted Jun 28, 2010 05:58 PM
    I'm trying to connect two Procurve 6600's to a 5406 with the SFP+ module.
    We originally specified HP direct attach cables, but there is a bit of a rush and our supplier told us that Cisco SFP+ branded cables would work. When I attach the cables the link light blinks orange and there is no connectivity.
    After some research I've learned that the SFP+ transievers on copper (or direct attach) can be "branded" for the manufacturer and that HP switches will only work with HP cables. Can anyone confirm this?
    If so I love that HP claims there cable is compliant with the standard, but then doesn't accept other standard compliant cables. So much for interoperability.
  • 2.  RE: SFP+ Direct Attach 10G cables
    Posted Jun 29, 2010 04:09 PM
    hi Marquis
    ProCurve or Cisco component don't support any other producer
    yess I product compliant standart but dont't work any other producer product
  • 3.  RE: SFP+ Direct Attach 10G cables
    Posted Jun 30, 2010 12:16 PM
    As you have discovered, your supplier was mistaken. They should not have told you that Cisco branded DACs would work with your ProCurve 6600 and 5406 switches.
    While it is called a "Direct Attach Cable" (DAC) is is really a cable hardwired to two transceivers. It isn't simply a cable, although many people seem to think of it that way - like a funny RJ45 cable. I don't think the IEEE fully appreciated what they wrought there. Perhaps they should have called it Direct Attach Transceivers.
    Just as with optical or CX4 transceivers, there are IDs, and various kit can and does check the IDs on the transceivers and make decisions. The firmware in the ProCurve 6600 and 5406 switches checks the IDs and will only accept those IDs it has been coded to "know" are both work and are supported.
