That's a bit odd looking to me. You might be able to get TAC to take a look at this based on that output, but the lack of an Aruba branded SFP might be troublesome.
Original Message:
Sent: Oct 12, 2023 10:17 AM
Subject: Sfp port issue on 7210's
Yes the transceiver is recognised. We don't have any Aruba branded ones but are using the same Cisco ones in other SFP+ ports.
I have just noticed though that the port configurations are not shown in the CLI running config on our controllers that are running OS 8.10.0.6. They are shown however on our controllers that are running 8.6.0.21 so maybe that is part of the problem?
8.10 controller:
[MDC] #show running-config | begin 0/0/0
Building Configuration...
[MDC] #
8.6 Controller:
[MDC] *#show running-config | begin 0/0/0
interface gigabitethernet 0/0/0
description "GE0/0/0"
trusted
trusted vlan 1-4094
no poe.................
Stewart Smith
ACMX, ACDX, ACCP, ACSA
Original Message:
Sent: Oct 12, 2023 09:43 AM
Have you tried with an Aruba branded SFP module? Does the transceiver get recognized when you insert into G0/0/4 or G0/0/5? The module you are using just may not work in the SFP+ ports.
Carson Hulcher, ACEX#110
Original Message:
Sent: Oct 12, 2023 09:24 AM
We have a strange issue on two 7210 controllers where we have a fibre sfp in port 0/0/0 connecting to a switch. The connections from port 0/0/0 on both controllers work fine. We want to use the copper port 0/0/0 for a different purpose so want to move the fibre connection to sfp port 0/0/5 which is free on both controllers. in both cases though the connection will not come up using port 0/0/5. We see this message in the log:
Oct 12 13:13:00 2023 fpapps[3632]: <399816> <3972> <ERRS> |fpapps| hapiPortLinkStatus: Speed unknown for port 0/0/5
The port is configured as an access port and the speed and duplex settings cannot be altered as it is an sfp port. If we move the connection back to port 0/0/0 it works fine. We have also tried port 0/0/4 and get the same issue.
Other details are:
#show interface gigabitethernet 0/0/5 transceiver
Module is SFP
Manufacturer : CISCO-AGILENT
Part Number : QFBR-5766LP , rev:
S/N : AGS103256NW
Date Code : 060811 Lot:
Supported Modes : 1000Base-SX, LC Connector
Wavelength : 850 nm
Aruba Certified : NO
We have also tried with single mode SFP's and cables but get the same issue. Any ideas?
Stewart Smith
