  • 1.  Shot myself in the foot with building test cppm cluster.
    Posted Nov 04, 2024 11:38 AM
    So built a test 2 node cppm cluster  running 6.12.3  ( 2000V appliances) all working fine.
    Then wanted to import  config from our.  production 6.11.9 cluster.
    Again that worked ... except ....
    Now the  master publisher is there but thinks its a standalone publisher.
    The original  subscriber  stil thinks its a subscriber to the master bublisher
    Can log onto both of them using appamin
    Can log onto  master publisher via gui
    Cannot log into  subscriber using. gui
    from CLI on  subscriber that was cannot. drop subscriber or reset database  from CLI
    How do I rejoin the old secondary to the master publisher.
    Annoyingly,  if I go into global cluster settings on the master publisher and  change the header that appears on the login page and then try logging into the (old)secondary, the change in header  appears, so theres some form of. sync there.
    No haven't tried the  switch it off and on again yet
    A
  • 2.  RE: Shot myself in the foot with building test cppm cluster.
    Posted Nov 04, 2024 12:05 PM
    The easiest option?  Delete the VMs, start over.
    Bring up one appliance, restore the backup from the publisher.
    Bring up the second appliance, join the new cluster.
    Carson Hulcher, ACEX#110
  • 3.  RE: Shot myself in the foot with building test cppm cluster.
    Posted Nov 04, 2024 12:16 PM
    Yup was just thinking that. Every other time i've done this, i've restored onto 1 appliance and then built the cluster around it
    Not me that builds the VM though .
    Surprised that there isn’t some command on the subscriber to cope with this silliness
    A
  • 4.  RE: Shot myself in the foot with building test cppm cluster.
    Posted Nov 04, 2024 12:27 PM
    The command cluster reset-database should do the job, but sounds like you've managed to get in a state where such isn't possible.  You might reset the publisher and then try again on the other appliance.
  • 5.  RE: Shot myself in the foot with building test cppm cluster.
    Posted Nov 04, 2024 12:33 PM
    Nope tried that, comes back with error saying node not found
    A
    Sent from my iPhone
  • 6.  RE: Shot myself in the foot with building test cppm cluster.
    Posted Nov 04, 2024 12:37 PM
    Then redeploy or open a case with TAC are probably your options.
