  • 1.  Should I need MM And MC to manage Aruba 515
    Posted Sep 02, 2019 11:16 AM
    Hey,
    When I config new configuration of Wifi 6 (Aruba 515)
    Should I MUST Mobility Master?
    Or just Mobility controller?
    what is the best way to manage aruba 51X series?
    Thank You!
  • 2.  RE: Should I need MM And MC to manage Aruba 515
    Posted Sep 02, 2019 12:25 PM
    Hi Ben,
    An Mobilty Master is not required but strongly recommended because without an MM you missed some important features like clustering, active/active nodes, live updates and airmatch.
  • 3.  RE: Should I need MM And MC to manage Aruba 515
    Posted Sep 03, 2019 04:07 AM
    The AP515 is a Unified AP, so if a Controller is not located it will act as a Instant AP and elect a Virtual Controller. The best way to manage the AP would be dependant on your requirements.
