  • 1.  signal strength
    Posted Oct 12, 2016 11:47 PM
    A smartphone is hardly getting RSSI -67 dBm while doing a survey .So Its sure that the second strongest signal should be less than -67 ,
    So do we need to care  abou this ?
  • 2.  RE: signal strength
    Posted Oct 14, 2016 07:39 PM
    I think -67 is a fine signal strength - depending on what you're expecting of course ;)
    We'd need to know a whole lot more about your environment to be able to give any meaningful advice. How far away from which model AP to start with.
  • 3.  RE: signal strength
    Posted Oct 15, 2016 05:03 PM
    Thanks for the reply ,I want to use cisco phone and some smartphones  for voip with excellent roaming
  • 4.  RE: signal strength
    Posted Oct 17, 2016 12:54 PM
    The signal strength you're seeing is not enough information to tell whether you'll have good VoIP roaming
    Your experience will be affected by: how large an area, what kind of environment, how many APs, what other WiFi users at the same time, how much interference - and at least 20 more things I haven't thought of.
    In my office environment with no interference to speak of and an AP every 75 feet or less, neg65 would work just fine.
