SLB AOS-W 5.0.4.5
  • 1.  SLB AOS-W 5.0.4.5
    Posted May 16, 2012 12:30 PM
    I may be wrong on this post but if anyone could provide a clarification, I'd appreciate it.
    Before SLB there was AP Load balancing in Code versions. Then after a certain cod level it was switched to SLB.
    In 5.0.4.5 next to the option to turn on SLB there is the option for SLB Mode which allows channel and radio which determine control over how the AP balances clients, channel based obviously balances clients across the channels and radio across the radio.
    Is using SLB in radio mode still a valid option?
