Comware
  • 1.  Slot A crashes - HPE 5406 zl2 / J9850A
    Posted Jun 23, 2021 05:41 AM
    I'm looking for some help with troubleshooting logging messages, which precede crash of one of the modules, causing it to be inoperative. Before crashing - switch is logging messages about "message buffer allocation", next all interfaces are going down.
    I've been looking for solution for quite some time, but without an effect. Could anyone give me a hand with this problem? What could be causing this log messages?
    Switch model HPE 5406 zl2 / J9850A
    I'm attaching logs below:
    I 06/12/21 13:06:36 00422 chassis: AM1: Slot A Ready
    M 06/12/21 13:06:34 04701 chassis: AM1: Slot A Software exception at alloc_free.c:598 -- in 'mtimexIM', task ID = 0x6bcb1240 -> No msg buffer
    I 06/12/21 13:06:25 00376 chassis: AM1: Slot A Download Complete
    I 06/12/21 13:06:25 00375 chassis: AM1: Slot A Downloading
    I 06/12/21 13:06:24 02568 chassis: AM1: Slot A Core Dump Uploading
    I 06/12/21 13:06:24 03846 InSysProg: AM1: Slot A: Checking for firmware updates.
    M 06/12/21 13:06:14 04701 chassis: AM1: Slot A crash detected - Available
    I 06/12/21 13:06:12 04665 macsec: AM1: The MACsec Connectivity Association ended on port XXX.
    I 06/12/21 13:06:12 00077 ports: AM1: port XXX in TrkX is now off-line
    W 06/12/21 13:04:51 03007 system: AM1: Slot A message buffer allocation has reached 99%
  • 2.  RE: Slot A crashes - HPE 5406 zl2 / J9850A
    Posted Jun 23, 2021 06:47 AM
    What is the current software version?
    Thanks!
  • 3.  RE: Slot A crashes - HPE 5406 zl2 / J9850A
    Posted Jun 23, 2021 06:49 AM
    Current software is:
    Software revision : KB.16.10.0012
  • 4.  RE: Slot A crashes - HPE 5406 zl2 / J9850A
    Posted Jun 23, 2021 07:18 AM
    I believe this is a bug in current running software: Software revision : KB.16.10.0012bug.JPG
    Below is the link for  release notes of KB.16.10.0015.
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00115452en_us
    Thanks!
  • 5.  RE: Slot A crashes - HPE 5406 zl2 / J9850A
    Posted Jun 23, 2021 11:27 AM
    Thank you for the reply. I'll upgrade firmware and let you know, if problem occurs again.
  • 6.  RE: Slot A crashes - HPE 5406 zl2 / J9850A
    Posted Jul 14, 2021 04:12 AM
    Problem occured again after updating the firmware to version:
    Software revision : KB.16.10.0015
    Same symthoms - switch generates logs:
    03007 system: AM1: Slot A message buffer allocation has reached XX%
    and after reaching 100% module A crashes.
    Any ideas?
  • 7.  RE: Slot A crashes - HPE 5406 zl2 / J9850A
    Posted Jul 14, 2021 05:38 AM
    Its strange issue is still there after upgrade.
    Can you plz share 'show log' output?
    Thanks!
  • 8.  RE: Slot A crashes - HPE 5406 zl2 / J9850A
    Posted Jul 14, 2021 09:59 AM
    Output of 'show logging' is in my first post. Occasionally switch logs messages (maybe it's somehow connected):
    W 07/12/21 23:07:13 00327 FFI: AM1: port XXX-Excessive undersized/giant packets. See help.
    W 07/12/21 22:54:13 00328 FFI: AM1: port XXX-Excessive jabbering/fragments. See Help
    Is there any command to show information about message buffer or to clear it?
    Regards
  • 9.  RE: Slot A crashes - HPE 5406 zl2 / J9850A
    Posted Jul 15, 2021 02:47 PM
    This message shows the interface received giant packet.
    Can you try to enable jumbo frame?
    Thanks!
  • 10.  RE: Slot A crashes - HPE 5406 zl2 / J9850A
    Posted Jul 26, 2021 09:30 AM
    I'm sorry for the delay.
    We use 10G transceivers, shouldn't jumbo frames be enabled automatically for these speeds?
    If not - which command should I use to enable it? Is it only vlan id jumbo?
    Regards
