If you have urgent issues, always contact your Aruba partner, distributor, or Aruba TAC Support.
for how to contact Aruba TAC.
Original Message:
Sent: Dec 13, 2024 07:36 AM
Subject: Slow Web Interface Response on Aruba 7008 Controller (Version 8.10.0.15)
Shen, were these outputs collected during issue? Were you able to collect HAR file? You can unicast me the HAR file.
Karthikeyan Mookkandi
Original Message:
Sent: Dec 12, 2024 09:29 AM
Hello, I have collected the relevant data and haven't found any significant issues.
(Aruba) [mynode] #show web-server profile
Web Server Configuration
Parameter Value
Enable provided cipher suites ECDHE-ECDSA-AES256-GCM-SHA384 ECDHE-ECDSA-AES128-GCM-SHA256 ECDHE-RSA-AES256-GCM-SHA384 ECDHE-RSA-AES128-GCM-SHA256 ECDHE-ECDSA-AES256-SHA384 ECDHE-ECDSA-AES128-SHA256 ECDHE-ECDSA-AES256-SHA ECDHE-ECDSA-AES128-SHA ECDHE-RSA-AES256-SHA ECDHE-RSA-AES128-SHA
SSL/TLS Protocol Config tlsv1.2
Switch Certificate default
Captive Portal Certificate default
IDP Certificate default
Management user's WebUI access method username/password
User absolute session timeout <30-3600> (seconds) 0
User session timeout <30-3600> (seconds) 3600
Maximum supported concurrent clients <25-320> 75
Enable WebUI access on HTTPS port (443) false
Enable bypass captive portal landing page false
Exclude Security Headers from HTTP Response false
VIA client-cert port number 8085
(Umetw-Aruba) [mynode] #
(Umetw-Aruba) [mynode] #show web-server statistics
Web Server(Non-Captive Portal) Statistics:
Current Request Rate: 1 Req/Sec
Current Traffic Rate: 0 KB/Sec
Busy Connection Slots: 2
Available Connection Slots: 73
Total Requests Since Up Time: 13167
Total Traffic Since Up Time: 110483 KB
Avg. Request Rate Since Up Time: 0 Req/Sec
Avg. Traffic Rate Since Up Time: 164 Bytes/Sec
Server Scoreboard _____________W_______________________________K_____________________________
Scoreboard Key: _ - Waiting for Connection, s - Starting up
R - Reading Request, W - Sending Reply
K - Keepalive, D - DNS Lookup
C - Closing connection, L - Logging
G - Gracefully finishing, I - Idle cleanup of worker
. - Open slot with no current process
Web Server(Captive Portal) Statistics:
Accepted Connections: 3
Active Connections: 1
Handled Connections: 3
Idle Connections: 0
Number of Requests: 3
(Umetw-Aruba) [mynode] # show datapath session verbose | include 192.168.88.254,Pa
Source IP or MAC Destination IP Prot SPort DPort Cntr Prio ToS Age Destination TAge Packets Bytes SIDX SRTI SRCI SRTRCV MI(Tun) SRTMIV UsrIdx UsrVer AclVer NhlIdx NhIdx NhlNhVer Flags CPU ID
172.16.11.10 192.168.88.254 6 4343 6450 0/0 0 0 0 0/0/0 11 642 856322 2d9 0 0 0 0 0 2 5 51a 0 0 0 6
192.168.88.254 172.16.11.10 6 6125 22 1/4098 0 0 0 0/0/0 138 226 18774 5be 0 0 0 0 0 0 0 0 0 0 0 C 6
192.168.88.254 172.16.11.10 6 6461 4343 1/4101 0 0 0 0/0/0 1 8 2333 71f 0 0 0 0 0 0 0 0 0 0 0 FC 6
172.16.11.10 192.168.88.254 6 4343 6451 0/0 0 0 0 0/0/0 10 320 414645 96d 0 0 0 0 0 2 5 51a 0 0 0 6
172.16.11.10 192.168.88.254 6 22 6125 0/0 0 4 0 0/0/0 138 173 23237 fb3 0 0 0 0 0 2 5 51a 0 0 0 6
192.168.88.254 172.16.11.10 6 6445 4343 1/4101 0 0 0 0/0/0 12 183 24590 109d 0 0 0 0 0 0 0 0 0 0 0 C 6
192.168.88.254 172.16.11.10 6 6450 4343 1/4101 0 0 0 0/0/0 12 355 29295 10ce 0 0 0 0 0 0 0 0 0 0 0 C 6
172.16.11.10 192.168.88.254 6 4343 6448 0/0 0 0 1 0/0/0 12 5 356 13f0 0 0 0 0 0 2 5 51a 0 0 0 F 6
172.16.11.10 192.168.88.254 6 4343 6449 0/0 0 0 1 0/0/0 12 5 356 1844 0 0 0 0 0 2 5 51a 0 0 0 F 6
192.168.88.254 172.16.11.10 6 6457 4343 1/4101 0 0 0 0/0/0 6 7 2229 21df 0 0 0 0 0 0 0 0 0 0 0 FC 6
192.168.88.254 172.16.11.10 6 6444 4343 1/4101 0 0 1 0/0/0 13 7 2293 392d 0 0 0 0 0 0 0 0 0 0 0 FC 6
192.168.88.254 172.16.11.10 6 6451 4343 1/4101 0 0 0 0/0/0 11 167 16561 397e 0 0 0 0 0 0 0 0 0 0 0 C 6
192.168.88.254 172.16.11.10 6 6448 4343 1/4101 0 0 1 0/0/0 13 7 2293 43ae 0 0 0 0 0 0 0 0 0 0 0 FC 6
192.168.88.254 172.16.11.10 6 6447 4343 1/4101 0 0 1 0/0/0 13 7 2229 43fd 0 0 0 0 0 0 0 0 0 0 0 FC 6
172.16.11.10 192.168.88.254 6 4343 6457 0/0 0 0 1 0/0/0 7 5 356 5623 0 0 0 0 0 2 5 51a 0 0 0 F 6
172.16.11.10 192.168.88.254 6 4343 6444 0/0 0 0 1 0/0/0 14 5 356 654a 0 0 0 0 0 2 5 51a 0 0 0 F 6
192.168.88.254 172.16.11.10 6 6449 4343 1/4101 0 0 1 0/0/0 13 7 2261 6a1e 0 0 0 0 0 0 0 0 0 0 0 FC 6
172.16.11.10 192.168.88.254 6 4343 6445 0/0 0 0 0 0/0/0 14 342 441382 6efe 0 0 0 0 0 2 5 51a 0 0 0 6
172.16.11.10 192.168.88.254 6 4343 6461 0/0 0 0 0 0/0/0 3 5 356 7230 0 0 0 0 0 2 5 51a 0 0 0 F 6
172.16.11.10 192.168.88.254 6 4343 6447 0/0 0 0 1 0/0/0 13 5 356 7fd7 0 0 0 0 0 2 5 51a 0 0 0 F 6
(Aruba) [mynode] # 2.168.88.254 6 4343 6444 0/0 0 0 1 0/0/0 14 5 356 654a 0 0 0 0
(Aruba) [mynode] #show datapath session dpi | include 192.168.88.254,Pa
Source IP or MAC Destination IP Prot SPort DPort Cntr Prio ToS Age Destination TAge Packets Bytes AclVer Int-Flag Sess-Flag2 PktsDpi UplnkVlan AppID AceIdx Flags DpiTIdx CPU ID ASliceId
172.16.11.10 192.168.88.254 6 4343 6490 0/0 0 0 0 0/0/0 2 7 1446 51a 4001 0 0 none (0 ) 16423/0 0 6 31
172.16.11.10 192.168.88.254 6 4343 6450 0/0 0 0 1 0/0/0 2d 948 1260822 51a 4001 0 0 none (0 ) 16423/0 F 0 6 31
192.168.88.254 172.16.11.10 6 6125 22 1/4098 0 0 0 0/0/0 154 267 21102 0 84000 0 0 none (0 ) 0/0 C 0 6 31
192.168.88.254 172.16.11.10 6 6491 4343 1/4101 0 0 0 0/0/0 2 7 3271 0 2084000 0 0 none (0 ) 0/0 C 0 6 31
172.16.11.10 192.168.88.254 6 4343 6451 0/0 0 0 0 0/0/0 2c 390 494194 51a 4001 0 0 none (0 ) 16423/0 0 6 31
172.16.11.10 192.168.88.254 6 4343 6491 0/0 0 0 0 0/0/0 2 7 1403 51a 4001 0 0 none (0 ) 16423/0 0 6 31
172.16.11.10 192.168.88.254 6 4343 6472 0/0 0 0 1 0/0/0 12 6 396 51a 4001 0 0 none (0 ) 16423/0 F 0 6 31
172.16.11.10 192.168.88.254 6 22 6125 0/0 0 4 0 0/0/0 155 235 35829 51a 4001 0 0 none (0 ) 16407/0 0 6 31
192.168.88.254 172.16.11.10 6 6445 4343 1/4101 0 0 0 0/0/0 2f 407 41623 0 84000 0 0 none (0 ) 0/0 C 0 6 31
192.168.88.254 172.16.11.10 6 6450 4343 1/4101 0 0 1 0/0/0 2e 487 41983 0 84000 0 0 none (0 ) 0/0 FC 0 6 31
172.16.11.10 192.168.88.254 6 4343 6488 0/0 0 0 0 0/0/0 6 6 396 51a 4001 0 0 none (0 ) 16423/0 F 0 6 31
192.168.88.254 172.16.11.10 6 6484 4343 1/4101 0 0 1 0/0/0 8 8 2301 0 84000 0 0 none (0 ) 0/0 FC 0 6 31
192.168.88.254 172.16.11.10 6 6475 4343 1/4101 0 0 1 0/0/0 f 8 2333 0 84000 0 0 none (0 ) 0/0 FC 0 6 31
172.16.11.10 192.168.88.254 6 4343 6475 0/0 0 0 1 0/0/0 f 5 356 51a 4001 0 0 none (0 ) 16423/0 F 0 6 31
192.168.88.254 172.16.11.10 6 6495 4343 1/4101 0 0 0 0/0/0 1 2 92 0 2084000 0 0 none (0 ) 0/0 C 0 6 31
192.168.88.254 172.16.11.10 6 6490 4343 1/4101 0 0 0 0/0/0 3 8 3226 0 2084000 0 0 none (0 ) 0/0 C 0 6 31
172.16.11.10 192.168.88.254 6 4343 6495 0/0 0 0 0 0/0/0 1 1 52 51a 4001 0 0 none (0 ) 16423/0 0 6 31
172.16.11.10 192.168.88.254 6 4343 6492 0/0 0 0 0 0/0/0 3 42 51653 51a 4001 0 0 none (0 ) 16423/0 0 6 31
192.168.88.254 172.16.11.10 6 6451 4343 1/4101 0 0 0 0/0/0 2d 218 33036 0 84000 0 0 none (0 ) 0/0 C 0 6 31
192.168.88.254 172.16.11.10 6 6485 4343 1/4101 0 0 0 0/0/0 8 8 2365 0 2084000 0 0 none (0 ) 0/0 FC 0 6 31
192.168.88.254 172.16.11.10 6 6470 4343 1/4101 0 0 1 0/0/0 13 8 2301 0 84000 0 0 none (0 ) 0/0 FC 0 6 31
192.168.88.254 172.16.11.10 6 6492 4343 1/4101 0 0 0 0/0/0 3 25 4655 0 2084000 0 0 none (0 ) 0/0 C 0 6 31
172.16.11.10 192.168.88.254 6 4343 6487 0/0 0 0 0 0/0/0 6 6 396 51a 4001 0 0 none (0 ) 16423/0 F 0 6 31
192.168.88.254 172.16.11.10 6 6472 4343 1/4101 0 0 1 0/0/0 12 8 2333 0 84000 0 0 none (0 ) 0/0 FC 0 6 31
192.168.88.254 172.16.11.10 6 6487 4343 1/4101 0 0 0 0/0/0 6 8 2269 0 2084000 0 0 none (0 ) 0/0 FC 0 6 31
172.16.11.10 192.168.88.254 6 4343 6445 0/0 0 0 0 0/0/0 2f 774 1029901 51a 4001 0 0 none (0 ) 16423/0 0 6 31
172.16.11.10 192.168.88.254 6 4343 6485 0/0 0 0 0 0/0/0 8 6 396 51a 4001 0 0 none (0 ) 16423/0 F 0 6 31
172.16.11.10 192.168.88.254 6 4343 6470 0/0 0 0 1 0/0/0 13 5 356 51a 4001 0 0 none (0 ) 16423/0 F 0 6 31
172.16.11.10 192.168.88.254 6 4343 6484 0/0 0 0 0 0/0/0 8 6 396 51a 4001 0 0 none (0 ) 16423/0 F 0 6 31
172.16.11.10 192.168.88.254 6 4343 6471 0/0 0 0 1 0/0/0 13 5 356 51a 4001 0 0 none (0 ) 16423/0 F 0 6 31
192.168.88.254 172.16.11.10 6 6488 4343 1/4101 0 0 0 0/0/0 6 8 2365 0 84000 0 0 none (0 ) 0/0 FC 0 6 31
192.168.88.254 172.16.11.10 6 6471 4343 1/4101 0 0 1 0/0/0 13 8 2301 0 84000 0 0 none (0 ) 0/0 FC 0 6 31
(Aruba) [mynode] # show netstat tcp | include httpd
LISTEN 0 150 :::32000 :::* users:(("httpd",pid=21103,fd=51),("httpd",pid=6942,fd=51))
LISTEN 0 150 :::80 :::* users:(("httpd",pid=21103,fd=26),("httpd",pid=6942,fd=26))
LISTEN 0 150 :::8082 :::* users:(("httpd",pid=21103,fd=28),("httpd",pid=6942,fd=28))
LISTEN 0 150 :::8084 :::* users:(("httpd",pid=21103,fd=30),("httpd",pid=6942,fd=30))
LISTEN 0 150 :::8085 :::* users:(("httpd",pid=21103,fd=40),("httpd",pid=6942,fd=40))
LISTEN 0 150 :::1111 :::* users:(("httpd",pid=21103,fd=38),("httpd",pid=6942,fd=38))
LISTEN 0 150 :::4343 :::* users:(("httpd",pid=21103,fd=36),("httpd",pid=6942,fd=36))
LISTEN 0 150 :::8089 :::* users:(("httpd",pid=21103,fd=32),("httpd",pid=6942,fd=32))
LISTEN 0 150 :::443 :::* users:(("httpd",pid=21103,fd=34),("httpd",pid=6942,fd=34))
ESTAB 0 0 ::ffff:172.16.11.10:4343 ::ffff:192.168.88.254:6445 users:(("httpd",pid=21103,fd=60))
ESTAB 0 0 ::ffff:172.16.11.10:4343 ::ffff:192.168.88.254:6451 users:(("httpd",pid=21103,fd=62))
ESTAB 0 0 ::ffff:172.16.11.10:4343 ::ffff:192.168.88.254:6490 users:(("httpd",pid=21103,fd=65))
(Aruba) [mynode] #show process monitor statistics | include httpd
/mswitch/bin/httpd_wrap PROCESS_RUNNING - 0 240 3 Wed Dec 4 23:24:40 2024
(Aruba) [mynode] #show processes | include httpd
0.0 S 5676 5265 13920 5568 4 0 Dec04 00:02:45 2b249cc8 /mswitch/bin/httpd_wrap
0.0 S 6942 5676 23456 12112 4 0 Dec04 00:00:06 2b969cc8 /mswitch/apache/bin/httpd -DFOREGROUND -DSSL -DCPv2
(Umetw-Aruba) [mynode] #show memory
Memory (Kb): total: 3069040, used: 1464432, free: 1604608
(Aruba) [mynode] #show storage
Filesystem Size Used Available Use% Mounted on
/dev/usb/flash3 1.4G 801.4M 599.5M 57% /flash
/dev/usb/flash3 1.4G 801.4M 599.5M 57% /flash/apimages
Original Message:
Sent: Dec 12, 2024 08:15 AM
Hi Shen,
Do you see this issue regularly? Did you try with different browser? When issue happens, please collect HAR file from browser and following outputs from CLI.
show datapath session verbose | include <client IP>,Pa
show datapath session dpi | include <client IP>,Pa
show memory
show storage
Original Message:
Sent: Dec 11, 2024 09:30 AM
Hi Airheads Community,I'm having trouble with my Aruba 7008 controller's web interface - it's super slow! Every time I try to access the management GUI, it takes forever to load. Really frustrating!What's happening:
- Takes ages to load the web interface pages
- Been like this for a while now
- Already tried upgrading firmware and resetting the controller, but no luck
Current Environment
- My setup:
- Controller: Aruba 7008
- Running version: 8.10.0.15 LSR
- 1~2 AP connected
- Around 10 users
- Been up for about 7 days
Issue Description
The web interface responds very slowly when accessing the management GUI. The issue persists:- After multiple firmware upgrades
- After controller reset
- Across different browser sessions
System Status
CPU and Memory- CPU Usage: Fluctuating between 9% to 46%
- Memory Usage: 2526496k used out of 3069040k total
- Regular warnings about CPU threshold exceeding 45%
Warning MessagesTroubleshooting Steps Taken
- Performed controller reset
- Upgraded firmware to multiple versions
- Monitored system resources and logs
- Regular maintenance procedures
