  • 1.  Slower download speeds than upload?
    Posted Aug 04, 2015 10:16 AM
    Hi
    We are noticing slower download speeds than upload? We have X2 3600 Master-Standby and a 3200 local controlller network with AP105's. We tested through our remote access SSID and VPN but got the same results through a different SSID with direct connection to our internal network?
    I have tested port and interface speeds and did not find a bottleneck? I also do not have bandwidth throttling?
  • 2.  RE: Slower download speeds than upload?
    Posted Aug 04, 2015 10:35 AM
    When you tested on wired were you using the same VLAN that you are using on wireless ?
    Did you tested from one of the controller wired ports?
    From the controller dashboard can you see the overall RF health : Noise , Channel utilization , SNR ?
    Do you have drop broadcast/multicast on the VAP turned on?
    How many SSIDs are you broadcasting ?
  • 3.  RE: Slower download speeds than upload?
    Posted Aug 04, 2015 11:24 AM
    Hi all tests are wireless, either through VPN or directly connected through a different SSID but same results, overal health on both controllers look good!
    We are broadcasting a max of 6 SSID's with a mix of PSK, Captive Portal and 802.1x.
    Drop broadcast/multicast on the VAP is off on all SSID's.
  • 4.  RE: Slower download speeds than upload?
    Posted Sep 08, 2015 12:53 PM
    how much of a difference are we talking about?
    have you tried the drop multicast / broadcast?
