  • 1.  Slowness in Wireless Bandwidth
    Posted Jan 07, 2019 06:05 AM
    Hi Gurus ,
    I am facing one issue regaridng the Wirelss , hope you can suggest any sloution for this . I have 2 SSID,s , 1 is having PSK and other is configured with 802.1x . We have 400 MBPS Link . The SSID whihc is having PSK is giving the proper speed /bandwidth but the SSID which is  having  802.1x  became very slow and its giving only 20mbps as tested in speed test . Could you please advise what parametrs i have to check and which sloution i can apply to rectifie this issue . Hope to get a reply from Gurus regarding this .
    Cheers .
    Muddy.
  • 2.  RE: Slowness in Wireless Bandwidth
    Posted Jan 07, 2019 06:25 AM
    - What is the output of "show ap active" or "show aps"?
    - Do you have broadcast filtering enabled?
    - What wireless client are youusing for your tests?
  • 3.  RE: Slowness in Wireless Bandwidth
    Posted Jan 07, 2019 06:45 AM
    Hi Cjoseph ,
    Thanks a lot for your reply , yeah i have applied the broadcast filtering . Please find the attcahed output of SH AP active , i am using a laptop for testing .
    Regards ,
    Muddy.
    Attachment(s)
    docx
    Logs For Aruba.docx   18 KB 1 version
  • 4.  RE: Slowness in Wireless Bandwidth
    Posted Jan 07, 2019 07:03 AM
    You have 40 and 80 mhz channels enabled which will cause alot of contention.  In the RF ARM profile, make sure that 80mhz channels is unchecked.
  • 5.  RE: Slowness in Wireless Bandwidth
    Posted Jan 08, 2019 12:25 AM
    Hi Cjoseph ,
    I will check and revert .
  • 6.  RE: Slowness in Wireless Bandwidth
    Posted Jan 09, 2019 06:36 AM
    Hi Cjoseph ,
    I have applied the changes but it didnt worked , bandwidth was still slow 20 mbps out of 400 mbps link  . Than i created anoter Test SSID and made the some changes ( i selected WPA 2 AES instead of TKIP in test SSID ) and implemented 802.1x for this new Test SSID when i made a speed test it was giving me almost 170 mbps means it was giving me the desired result . So i replicated the Same configuration for my Staff SSID and its working fine now . I am attaching the screenshots of the changes which i have made on WLC and it had solved my issue .Hope if anybody else facing this issue it might give them some relief . I am really thankful to you and all other community members who are trying to help others .
    Cheers ,
    Muddy.
  • 7.  RE: Slowness in Wireless Bandwidth
    Posted Jan 09, 2019 09:08 AM
    The TKIP standard limits you to 54 megs.  It is also insecure, so don't use it.
