Cloud Managed Networks
  • 1.  SNMP for AOS10 APs
    Posted Apr 06, 2024 04:27 AM
    Hi all,
    I can't find SNMP for AOS10 APs, is that correct?
    I found in the guide that Microbranch AOS10 APs can configure SNMP, but it seems like it was removed from standard AOS10 APs.
    https://www.arubanetworks.com/techdocs/central/2.5.8/content/aos10x/cfg/mb-deploy/mb_ext_integ_snmp.htm?Highlight=snmp
    We would like to add the APs to our monitoring system ionstead of integrating the Central API.
    Bjarne
  • 2.  RE: SNMP for AOS10 APs
    Posted Apr 07, 2024 09:16 PM
    I think your best option is APIs.  I think the a subset of latest AOS 8 MIBs should work.
    There was no mention of it in the What's New section of Aruba Central/AOS10.6
