On the CLI, do the following command - "show snmp inform stats". Do you see overflows?
Check the IP Address for the SNMP host. Are you sure it should be 144.30.1.234?
Is there anything that would block UDP/162?
Do you filter at the receiver (only allow certain IP addreses to send informs)? Make sure you are allowing the correct address to send them to your host.
Also, as chrisbrizzell said, make sure your receiver is not overloaded.
