Network Management
  • 1.  SNMP Temperature monitoring
    Posted May 27, 2021 01:53 PM
    Edited by ER72 May 27, 2021 01:53 PM
    We have a mixed setup with switches from different generations, I know some don't have any way of monitoring temperature (25xx) but others definitely do have temperature data that is exposed through the WebUI but is not available over SNMP.
    Specifically CX8320 and CX6400 (running 10.06.0101), the weird thing to me is that we also have CX6300 switches which run the same firmware as the 6400 and they do expose some temperature data over SNMP (they actually only expose a single reading while the WebUI shows many more sensors).
    So am I just looking at the wrong SNMP table (1.3.6.1.2.1.99.1.1.1 - ENTITY-SENSOR), is this a setting I need to enable or is this a known bug/missing feature?
    Thanks!
    Keeper of the Keys
  • 2.  RE: SNMP Temperature monitoring
    Posted Jul 26, 2021 05:11 PM
    Bump
    Keeper of the Keys
  • 3.  RE: SNMP Temperature monitoring
    Posted Jul 27, 2021 03:20 PM
    use APi (for CX), you have all same temperature like Web GUi
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
