I checked internally and found that this message can be because SNMP traps cannot be sent, like the trap destination is not reachable.
And for Airwave managed controllers/conductors this message is expected and can be ignored:
"Airwave does send an empty get request every time a session is created. In this case, during the unresponsive state of the controller, airwave is trying to create a session and sending an empty get request message. That is why the controller is replying with this report message and hence we are throwing this warning message."
It may be good to open a TAC case to get a confirmation if this is the case in your situation as well.
Original Message:
Sent: Jan 02, 2024 02:45 PM
Subject: SNMP V3 Message parse error: Not in life time window failure in case of authoritative local engine id.
Thanks Herman.
I re-checked and all NTP configs and reachability are good, and devices are all in sync.
Curious about the 'WARNING' regarding the local-interface.
[mynode] #show ntp servers
NTP version is ntp-4.2.8p15.
NTP Server Table Entries
Flags: * Selected for synchronization
+ Included in the final selection set
# Selected for synchronization but distance exceeds maximum
- Discarded by the clustering algorithmn
= mode is client
remote local st poll reach delay offset disp
=14@.@@@.@@@.14 10.8.36.70 1 1024 377 0.00021 +0.000097 0.01074
*14@.@@@.@@@.238 10.8.36.70 1 1024 377 0.00258 +0.000058 0.00871
=14@.@@@.@@@.254 10.8.36.70 1 1024 377 0.01141 +0.000046 0.01030
=14@.@@@.@@@.142 10.8.36.70 1 1024 377 0.00174 +0.000092 0.00905
:-WARNING-:
Upstream NTP Server(s) are configured, but NOT reachable via local-interface!
Original Message:
Sent: Jan 02, 2024 08:15 AM
The message 'Not in life time window' would suggest me to have a look at the time on all of your devices. It's recommended to use NTP to synchronize the device clock to the same time source.
Original Message:
Sent: Dec 28, 2023 03:13 PM
Seeing this in all MC/WC devices and would like to understand what is going on and how to resolve the problem.
MC/WC devices are all provisioned in Airwave.
Dec 4 07:27:15 2023 snmp[3845]: <301135> <3845> <WARN> |snmp| SNMP V3 Message parse error: Not in life time window failure in case of authoritative local engine id.
Dec 4 07:29:19 2023 snmp[3845]: <301135> <3845> <WARN> |snmp| SNMP V3 Message parse error: Not in life time window failure in case of authoritative local engine id.
Dec 4 07:30:28 2023 snmp[3845]: <301135> <3845> <WARN> |snmp| SNMP V3 Message parse error: Not in life time window failure in case of authoritative local engine id.
Happy New Year
