Hello, I'm little bit at lost with regard to SNMPv3 settings on ArubaOS-Switch 16.05 (actually I'm working with Aruba 5400R zl2 switch series but switches family is a little bit irrelevant) and device discovery from the HPE IMC 7.3 (E0605) using SNMP/SSH and Telnet templates.
Actually SNMPv3, SSH and Telnet are enabled switch side, Switch is also pingable from HPE IMC host.
I've hardened SNMP service at Switch level using suggestion taken from ArubaOS-Switch Hardening Guide for 16.04 manual (Revision 1 April 2018) at SNMPv1/2c vs. SNMPv3 chapter...so actually the Aruba 5400R zl2 owns this SNMPv3 configuration (with no SNMP Community, as you can see):
HPE5412Rzl2(config)# show snmpv3 enable
Status and Counters - SNMP v3 Global Configuration Information
SNMP v3 enabled : No
HPE5412Rzl2(config)# snmpv3 enable
SNMPv3 Initialization process.
Creating user 'initial'
Authentication Protocol: MD5
Enter authentication password: ***************
Privacy protocol is DES
Enter privacy password: *****************
User 'initial' has been created
Would you like to create a user that uses SHA? [y/n] y
Enter user name: my-snmpv3-user
Authentication Protocol: SHA
Enter authentication password: *****************
Enter privacy password: ******************
User creation is done. SNMPv3 is now functional.
Would you like to restrict SNMPv1 and SNMPv2c messages to have read only
access (you can set this later by the command 'snmpv3 restricted-access')? [y/n] y
SNMP v3 enabled : Yes
HPE5412Rzl2(config)# show snmpv3 user
User Name Auth. Protocol Privacy Protocol
my-snmpv3-user SHA CBC DES
initial MD5 CBC DES
HPE5412Rzl2(config)# snmpv3 only
HPE5412Rzl2(config)# no snmp-server community public
HPE5412Rzl2(config)# show snmpv3 group
Security Name Security Model Group Name
CommunityManagerReadOnly ver1 ComManagerR
CommunityManagerReadWrite ver1 ComManagerRW
CommunityOperatorReadOnly ver1 ComOperatorR
CommunityOperatorReadWrite ver1 ComOperatorRW
CommunityManagerReadOnly ver2c ComManagerR
CommunityManagerReadWrite ver2c ComManagerRW
CommunityOperatorReadOnly ver2c ComOperatorR
CommunityOperatorReadWrite ver2c ComOperatorRW
HPE5412Rzl2(config)# snmpv3 group managerpriv user my-snmpv3-user sec-model ver3
my-snmpv3-user ver3 ManagerPriv
HPE5412Rzl2(config)# no snmpv3 user initial
HPE5412Rzl2(config)# snmpv3 user my-snmpv3-user auth sha 17-chars-long-password priv aes 18-chars-long-password
my-snmpv3-user SHA CFB AES-128
HPE5412Rzl2(config)# snmpv3 restricted-access
HPE5412Rzl2(config)# show snmpv3 restricted-access
SNMP v1 and SNMP v2c messages restricted to read only : Yes
Also note that SNMPv3 User my-snmp-user's Authentication and Privacy Passwords are, respectively, 17 and 18 characters long.
Under IMC -> System -> Resource Management -> Access Parameters Template and I have added ex-novo three SNMP, Telnet and SSH templates customized with access parameters valid for the Aruba 5400R zl2 I deployed, so using SNMP, SSH and Telnet credentials. Note that I didn't remove default templates already present on SNMP and Telnet. SSH hadn't a default template.
Now the issue:
- If I test (concurrently or singularly) SNMP, SSH and Telnet accesses to the Aruba 5400R zl2 by creating a batch operation (via IMC -> Resource -> Batch Operation -> Check Access Settings) and running it immediately I always end with failure(s)
- if, instead, I test SSH and Telnet singularly by selecting the Switch and performing "Test" under Configure -> Modify SSH Settings and Modify Telnet Settings: SSH and Telnet tests do pass.
- If I test singularly by selecting the Switch and performing "Test" under Configure -> Modify SNMP Settings: SNMP test doesn't pass.
So now questions:
- How can I check if SNMPv3 settings configured above are correct?
- Do I need a SNMP Community - after all - with snmp-server community public?
- Should I re-enable by issuing no snmpv3 restricted-access (that will be a little bit counter-intuitive since we need hardened SNMPv3) given that on Initial ArubaOS Switch Configuration is explicitly advised that "restricting access to only SNMPv3 messages makes the community named “public” inaccessible to network management applications (such as autodiscovery, traffic monitoring, SNMP trap generation, and threshold setting) from operating in the ArubaOS switch. For that reason, Aruba recommends answering no to Step 8 (which is the last step of snmp enable command listed above)"?
- Batch operations use default templates? or, better said, how can I check which templates are activated with regards to verifying access credentials to SNMP, SSH and Telnet via Batch Operations?
