Network Management
  • 1.  snmpv3 on 2920
    Posted May 08, 2025 07:15 AM
    Hi all,
    i am new on aruba and i have a model that is not the same like 6300m, i configured snmpv3 enable
    the i add ip authorized-manager 10.10.10.10 access manager
    also snmpv3 user user1 auth sha pass priv aes256 pass
    and snmpv3 group managerpriv user "user1" sec-model ver3.
    for snmp3 do i need community?  the vrf context should be the default i dont use the oobm.
    did i forget something?
    Thanks alot.
  • 2.  RE: snmpv3 on 2920
    Posted May 09, 2025 04:05 AM
    This is what I have on a 2930F, it probably is the same/similar on 2920 (PVOS/AOS-S):
    snmpv3 enable
    snmpv3 only
    snmpv3 restricted-access
    snmpv3 group managerpriv user "airwave" sec-model ver3
    snmpv3 user "airwave" auth sha "removed" priv aes "removed"
    Note that aes-256 is a 'non standardized' encryption for SNMPv3, there are different incompatible (vendor) versions of aes-256; so that may be a reason that it doesn't work. In that case try aes, which is aes-128 and see if that works.
  • 3.  RE: snmpv3 on 2920
    Posted May 12, 2025 07:23 AM
    thanks the aes was the issue.
  • 4.  RE: snmpv3 on 2920
    Posted May 09, 2025 04:34 AM
    This is from my test 2920 managed via central.
    snmpv3 enable
    snmpv3 group managerpriv user "user-inform" sec-model ver3
    snmpv3 notify "name_xxxxxxxx" tagvalue "tag_xxxxxxxx"
    snmpv3 targetaddress "target_xxxxxxxx" params "param_xxxxxxxx" xx.xx.xx.xx taglist "tag_xxxxxxxx"
    snmpv3 params "param_10100055" user "user-inform" sec-model ver3 message-processing ver3 priv
    snmpv3 user "user-inform" auth sha "" priv aes ""
    As I'm aware only SHA-1 and AES-128 are supported.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
  • 5.  RE: snmpv3 on 2920
    thanks a lot. The problem was on the AES256, i dont know why was possible to configure and it dosent worked but i changed it and everything was ok.
