Network Management
Some questions about Airwave generated reports.
  • 1.  Some questions about Airwave generated reports.
    Posted Nov 07, 2014 08:32 PM
    I usually do a report every week and I generate my own custom Airwave report for this. One time, they ask me the meaning of some numbers and here are some I couldn't answer (attached). I hope someone can clear this up.
    Thank you.
  • 2.  RE: Some questions about Airwave generated reports.
    Posted Nov 07, 2014 10:30 PM
    The reason you may not see the same numbers on the Unique Clients vs Total type of devices is because it will be based on the type of devices seen on each SSID .
    Signal Quality is the SNR value
    2014-11-07 22_26_43-How to_ Define Minimum SNR Values for Signal Coverage.png
