SONOS Airgroup issues
  • 1.  SONOS Airgroup issues
    Posted Nov 07, 2024 06:32 PM
    Edited by vvajpeyi Nov 08, 2024 11:48 AM
    Hello, I have been scouring for information to troubleshoot connecting SONOS speakers to an ARUBA network.  I have the services IDs defined but if I run the service blocked command some of the same service IDs that should be allowed are being blocked.
    My cluster is 8.10.13
    My cluster Airgroup is centrally managed with CLP and the RFC servers . The default services are disallowed by a GUEST OPEN role. The functional roles for our guest and .1x are guest and authenticated. I am using CLP registration which I have done..BCMC for MDNS is enabled of course which I will not be bale to disable. I do not have IGMP snooping enabled which I would have to take time to consider doing as it might become a info sec policy review.
    clearpass
    5999
    The the speakers I am trying to connect are landing on the same Vlan.
    Thank you
    AirGroup Information
    Feature               Status
    AirGroup version      ver2
    AirGroup mode         Centralized
    Active domain         NA
    Network Profile       default
    MDNS                  Enabled
    DLNA                  Enabled
    Enforce Registration  Enabled
    IPV6                  Disable
    AirGroup Service Information
    Service             Status
    default-airplay     Enabled
    default-airprint    Enabled
    default-itunes      Enabled
    default-remotemgmt  Enabled
    default-sharing     Enabled
    chat                Enabled
    default-googlecast  Enabled
    default-amazontv    Enabled
    default-dial        Enabled
    default-dlna-print  Enabled
    default-dlna-media  Enabled
    SONOS               Enabled
    apple-mirror        Enable
    default-dlna-media
    urn:schemas-upnp-org:device:MediaPlayer:1                AP-Name(Default)  15           0
    urn:schemas-upnp-org:device:MediaRenderer:1                                1316         65
    urn:schemas-upnp-org:device:MediaRenderer:2                                15           1
    urn:schemas-upnp-org:device:MediaRenderer:3                                15           0
    urn:schemas-upnp-org:device:MediaServer:1                                  782          1
       urn:schemas-upnp-org:device:MediaServer:2                                  15           0
     urn:schemas-upnp-org:device:MediaServer:3                                  15           0
     urn:schemas-upnp-org:device:MediaServer:4                                  15           0
      urn:schemas-upnp-org:device:ZonePlayer:1                                   42           0
     urn:schemas-upnp-org:service:AVTransport:1                                 15           63
       urn:schemas-upnp-org:service:AlarmClock:1                                  15           0
       urn:schemas-upnp-org:service:ConnectionManager:1
    SONOS
    _sonos._tcp                                              AP-Name(Default)  0            0
      _spotify-connect._tcp                                                      0            0
     urn:schemas-sonos-com:service:Queue:1                                      0            0
    urn:schemas-tencent-com:service:QPlay:1                                    0            0
     urn:schemas-upnp-org:service:AudioIn:1                                     0            0
    urn:schemas-upnp-org:service:EmbeddedNetDeviceControl:1                    0            0
     urn:schemas-upnp-org:service:HTControl:1                                   0            0
    urn:schemas-upnp-org:service:RenderingControl:1                            0            0
    urn:smartspeaker-audio:service:SpeakerGroup:1                              0            0
    blocked services that have been added to SONOS and are in the DLNA defaults
    urn:schemas-upnp-org:service:AudioIn:1                2479       Response
    urn:smartspeaker-audio:service:SpeakerGroup:1         45063    Query/Response  DLNA
