Hi Safranek, Did you solve this one as I have a similar setup ie.. Sonos on a different vlan to the users. Also have spotify connect to get running which is a complete different issue.
From my understanding we have to also present both vlans to the APs so the multicasts can be seen.
Original Message:
Sent: May 28, 2024 03:23 AM
Subject: Sonos system not working however airgroup was enabled
Yes, I tried that also.
The S in IOT stands for Security.
Original Message:
Sent: May 27, 2024 08:18 PM
Have you enabled DLNA and DLNA Media Service?
Original Message:
Sent: May 27, 2024 07:47 PM
Hi Guys,
I tried to set up a Sonos system on Aruba wireless network. The problem is that Sonos devices are on SSID1 (eg. vlan10), mobile devices are on SSID2 (eg. vlan20). I read about that airgroup needed for that, so I made configurations, I checked, airgroup is working (show airgroup servers list Sonos devices), however Sonos app doesn't find Sonos devices. If I put the mobile device on the same SSID/vlan where are Sonos devices, it works of course.
Airgroup configuration:
airgroup enable multi-swarm enable-guest-multicastairgroupservice airplay disable description AirPlayairgroupservice airprint disable description AirPrintairgroupservice Sonos enable id urn:schemas-upnp-org:service:GroupRenderingControl:1 id urn:schemas-sonos-com:service:Queue:1 id urn:schemas-upnp-org:service:AVTransport:1 id urn:schemas-upnp-org:service:RenderingControl:1 id urn:schemas-tencent-com:service:QPlay:1 id urn:schemas-upnp-org:service:GroupManagement:1 id urn:schemas-upnp-org:service:ZoneGroupTopology:1 id urn:schemas-upnp-org:service:DeviceProperties:1 id urn:schemas-upnp-org:service:MusicServices:1 id urn:schemas-upnp-org:service:AlarmClock:1 id urn:schemas-upnp-org:device:ZonePlayer:1 id urn:schemas-upnp-org:service:SystemProperties:1 id urn:schemas-upnp-org:service:ContentDirectory:1 id urn:schemas-upnp-org:service:ConnectionManager:1 id urn:schemas-upnp-org:service:HTControl:1 id urn:smartspeaker-audio:service:SpeakerGroup:1 id urn:schemas-upnp-org:service:VirtualLineIn:1 id _sonos._tcp id _spotify-connect._tcp id _companion-link._tcpairgroupservice allowall enable
I also set this on SSID1 and SSID2 also:
broadcast-filter none
multicast-rate-optimizationdynamic-multicast-optimization
xx:xx:xx:xx:xx:xx# show airgroup servers
AirGroup Servers
MAC IP Type Host Name Service VLAN Wired/Wireless Role Group Name AP-Name
aa:aa:aa:aa:aa:aa 192.168.30.194 mDNS,DLNA Sonos-aaaaaaaaaaaa Sonos 10 wireless SSID1 xx:xx:xx:xx:xx:xx
bb:bb:bb:bb:bb:bb 192.168.30.195 DLNA Sonos 10 wireless SSID1 SonosZP xx:xx:xx:xx:xx:xx
Num Servers: 2.
OS: 8.12.0.1_89864
What can be the problem?
