  • 1.  Spectrum Load balancing predetermined thresholds
    Posted Dec 04, 2014 04:57 AM
     Hi expert:
    Where could I configure predetermined threshold of spectrum load balance?Search user guid but
    Thanks!
  • 2.  RE: Spectrum Load balancing predetermined thresholds
  • 3.  RE: Spectrum Load balancing predetermined thresholds
    Posted Dec 04, 2014 07:10 AM
    @Colin Wang wrote:
     Hi expert:
    Thanks!
    Colin Wang,
    Please be advised that on ArubaOS 6.3 and above, ClientMatch replaces spectrum load balancing.  If you have Clientmatch enabled, the spectrum load balancing algorithm is not active.
  • 4.  RE: Spectrum Load balancing predetermined thresholds
    Posted Dec 04, 2014 10:41 PM
    Thanks for reply ,I still wonder for one thing.
    Since "Legacy 802.11a/b/g devices do not support the client match feature" ,is it possible that we only enable SLB for 802.11 a/b/g ,then we enable client match for rest of device. or we just disable clientmatch as device use 802.11n or ac always don't have performence issue.
  • 5.  RE: Spectrum Load balancing predetermined thresholds
    Posted Dec 05, 2014 04:15 AM
    Colin Wang,
    Legacy 802.11a/b/g ACCESS POINTS do not support clientmatch.  If you have 802.11n or 802.11ac access points, they will support Clientmatch, and you should be fine, even with 802.11a/b/g clients.
