  • 1.  Spectrum monitoring - Hardware compatibility
    Posted Dec 12, 2019 01:00 PM
    I just owned an AP-505, and while trying to enable the Spectrum Monitoring on the radio interfaces (Instant 8.6.0.0), an error message is displayed saying
    "Spectrum Monitoring is not supported on wifi0 radio of AP-505"
    Pretty strange behavior as SM has always been supported on all IAP hardware (IAP-105 for example).
    Is this a new software limitation ?
    Do you if this behavior may change ?
    And mostly, where can I find a SM compatibility matrix ?
    Many thanks for your help
    Jeremy
  • 2.  RE: Spectrum monitoring - Hardware compatibility
    Posted Dec 12, 2019 07:24 PM
    do you mean "background spectrum monitoring"in Instant 8.6.0
    under Configuration->RF->Radio->2.4?
  • 3.  RE: Spectrum monitoring - Hardware compatibility
    Posted Dec 17, 2019 09:26 PM
    Spectrum analysis is not supported in 8.6.0.0 on AP-50x. This will be addressed in an upcoming release.
    8.6 release notes are being updated, since this defect is not currently covered.
