Split-tunnel activated on guest profil
  • 1.  Split-tunnel activated on guest profil
    Posted Nov 14, 2019 08:55 AM
    In the default config on aruba IAP, split-tunnel is activated.
    In that case, the destination to all this private subnet will not be tunneled ?
    10.0.0.0 - 10.255.255.255
    172.16.0.0 - 172.31.255.255
    192.168.0.0 - 192.168.255.255
    Thank you in advance for your help.
  • 2.  RE: Split-tunnel activated on guest profil
    Posted Nov 14, 2019 11:01 AM
    Any help please ?
  • 3.  RE: Split-tunnel activated on guest profil
    Posted Nov 15, 2019 05:18 AM
    I finally found the answer for anyone who's interested :
    If split-tunnel is enabled, only corporate traffic is forwarded via the vpn tunnel based on the vpn route, others will be SRC-NATed via the master IAP local IP and forwarded locally.
    So you must configure a netdestination for the corporate subnets to forwarded via the tunnel. “permit” implies tunneling, which is used for corporate traffic, and “route” implies local bridging,
    which is used for local traffic.
    You must install the Policy Enforcement Firewall license in the controller. Apply the session ACL to a user role.
    https://fr.slideshare.net/ArubaNetworks/emea-airheads-aruba-instant-ap-vpn-troubleshooting
    https://community.arubanetworks.com/aruba/attachments/aruba/108/1002/1/split-tunneling.pdf
    Regards Brahim,
