I built a new server, installed iMC and matched it to the current production server as far as settings. Initial install was successful including the SQL database installs. I could log into the IMC web gui and see a basic setup. I did the local restore and it seemed to run the restore until the very end when I received the "database restore failed" error. In the dbman_debug see the error below. The services started up and everything looks (in the web GUI) to be working, but I want to confirm before I open try to figure out how to get the new server licensed.
Anyone seen this error and should I even worry since everything looks correct?
2021-10-22 14:01:03 [DEBUG] [Remove] Remove file: C:\Program Files\iMC\dbman\bin\dbop.sql.log
2021-10-22 14:01:03 [INFO] [DBMAN] Begin to restore file 10.21.0.98@icc_dbimc_icc
2021-10-22 14:01:03 [INFO] [CDbRestore::RestoreDatabaseList] m_PrimaryHost = 1, db remote_file_dir change to:
2021-10-22 14:01:03 [INFO] [Client::connect_to_server] Starting connect to 10.21.0.98: 2810
2021-10-22 14:01:03 [INFO] [Client::connect_to_server] Established connection to 10.21.0.98: 2810
2021-10-22 14:01:03 [ERROR] [Client::send_filetrans_msg] Send file data error expect 1024 bytes infact -1 bytes
2021-10-22 14:01:03 [INFO] [CDbRestore::RestoreOneDBase] File trans failed
2021-10-22 14:01:03 [ERROR] [CDbRestore::RestoreDatabaseList] Fail to restore DB file in RestoreOneDBase Function 10.21.0.60@icc_db_imc_icc_db_20211022_105358_full.db
2021-10-22 14:01:03 [INFO] [ManualRestoreBase] req asn msg:{ -- SEQUENCE --
iErrCode 'f6'H --
iContent '6963635f64623b3137322e32312e302e3938'H -- "icc_db;10.21.0.98" --
2021-10-22 14:01:03 [INFO] [sendTrapAlert] Send trap success
2021-10-22 14:01:03 [ERROR] [ManualRestoreBase] Failed to manual restore databases. ManualType: 0
2021-10-22 14:01:03 [ERROR] [response_err_code] errCode = -10
2021-10-22 14:01:03 [INFO] [ManualRestoreBase] Begin start service.
