It's by design that you can't edit/view/copy the filters for the default authentication sources (the ones between [brackets]) starting with ClearPass 6.11.0.
As a best practice, you should never change default profiles and always create and use your own modified version.
The risk with changing [default profiles] in most products, is that on an upgrade the new defaults will be applied and your changes are lost.
If you don't like the new behavior, please open an Innovation Zone request, and/or work with your local Aruba SE to get this raised; but as mentioned this change was implemented intentionally.
Original Message:
Sent: Jan 20, 2023 09:48 AM
Subject: SQL filter query missing on 6.10.8 and 6.11.0
Hi Bjarne
I think I have read something that you will not be able to edit default objects like [Time Source] from version 6.11.0. But can't find the text right now.
Have verified your observations and I can edit the filter on 6.10.7, but not on 6.10.8 or 6.11.0.
It's not possible to copy the default [Time Source] either...
I hope a fix will be released as some of my customers also have edited time sources.
A ticket to Aruba TAC may be a good idea in this case.
Best Regards
Jonas Hammarbäck
MVP 2023, ACCX #1335, ACMP, ACDP, ACP-Network Security, ACEP, ACSA
Aranya AB
Original Message:
Sent: Jan 20, 2023 09:34 AM
Hi all,
after updating CPPM to 6.10.8 or 6.11.0 we can no longer edit our SQL filter queries in authentication sources.
This is how it looked before the update:
And this is how it looks after the update / upgrade:
We have customers with modified queries that can not edit those anymore. Is this a known bug and is it going to be fixed?
Because I did not find anything about it in the Release Notes that indicates that this was a conscious change.
Bjarne
