  • 1.  SSH to iAP 505 using public key......how?
    Posted Jul 06, 2023 06:21 AM
    I would like to SSH onto Instant APs and VCs without using username & password for admin.
    How do I install my SSH public key onto the AP?
    What format should the file be in?
    Is it the "Public" or the "Client" certificate....if either? :)
    Thank you.
    Andy.
  • 2.  RE: SSH to iAP 505 using public key......how?
    Posted Jul 07, 2023 07:22 AM
    Check this discussion. It is for ArubaOS controllers, but likely will work for Instant as well..
  • 3.  RE: SSH to iAP 505 using public key......how?
    Posted Jul 07, 2023 08:50 AM
    Thank you Herman.....that does help a lot.
    Now to try and get the correct file format :-)
