Wired Intelligent Edge
  • 1.  SSH to MGMT port
    Posted Jan 17, 2024 03:30 PM
    My problem is that I cannot SSH to the MGMT interface.
    I am using EVE-NG (latest version, VM is fully up to date).  I have a CX 10.12 Simulator attached with Interface 1/1/1 and mgmt.
    Running config of switch
    hostname SPINE2
    ssh server vrf default
    ssh server vrf mgmt
    vlan 1
    interface mgmt
        no shutdown
        ip dhcp
    interface 1/1/1
        no shutdown
        no routing
        vlan access 1
    interface vlan 1
        ip address 192.168.32.122/24
    ip route 0.0.0.0/0 192.168.32.1
    https-server vrf mgmt
    config of mgmt interterface
    SPINE2# show int mgmt
      Address Mode: dhcp
      Admin State: up
      Link State: up
      Mac Address: 50:00:00:04:00:00
      IPv4 address/subnet-mask: 192.168.32.95/24
      Default gateway IPv4: 192.168.32.1
      Primary Nameserver: 192.168.32.250
    I am successfully able to SSH to the VLAN1 access port, but I cannot SSH to the mgmt port.
    When I test if port 22 is open on each interface, I can prove that 1/1/1 is listening (via vlan1).
    However mgmt is not listening on tcp/22 (ICMP is successful though).
    SSH is enabled on the mgmt VRF (as shown in the config), and there is not any ACLs on the SSH sessions.
    Any ideas?
  • 2.  RE: SSH to MGMT port
    Posted Jan 17, 2024 04:31 PM
    I don't understand your setup.
    • Seems like your test is done from your PC to ArubaCX1.
    • I see only your PC (HomeNET) connected to ArubaCX1 1/1/1, why i don't see HomeNET connected to ArubaCX1 mgmt?
    • ArubaCX10-12 seem irrelevant here.
    Marcel Koedijk | MVP Expert 2023 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 3.  RE: SSH to MGMT port
    Posted Jan 18, 2024 01:45 AM
    If you would like to access switches via mgmt port from outside the emulated environment, then connect them to management network.
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
  • 4.  RE: SSH to MGMT port
    Posted Jan 18, 2024 03:19 AM
    Thank you.  I didn't realise I could have more than one thing attached to the Management bridge, that's why I was using ArubaCX1 as an aggregate to SSH to ArubaCX10-12.  It is weird though why I couldn't hop through that to the mgmt port, but I could SSH to VLAN1 via port 1/1/1.
    I've made that change and I can now SSH to my mgmt port.
    Thanks again.
  • 5.  RE: SSH to MGMT port
    Posted Jan 18, 2024 03:25 AM
    Edited by GorazdKikelj Jan 18, 2024 03:30 AM
    Hi Tom.
    You could also use intermediate switch but you need to route traffic accordingly. More work to do. It is easier just to connect mgmt ports to Management network.
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
