At least have jumbo enabled on the switch ports-VLANs that connect to the AP, controller, and any links that are between switches on the path between AP/controller.
The point is that tunneled traffic adds a few bytes for the GRE tunnel and if it exceeds the MTU at any point in the path, packets may be dropped or fragmented, resulting in degraded performance.
Original Message:
Sent: Oct 10, 2023 04:30 AM
Subject: SSID in tunnel mode slow that Bridge SSID
Do you mean we might to enable the jumbo frame at controller (firewall enable jumbo processing and controller port), then AP in default ap system (SAP MTU) and switch port to AP and Controller?
Original Message:
Sent: Oct 09, 2023 11:00 AM
If you are trying to optimize the tunneled throughput you'll need to make sure that jumbo frames are enabled and allowed between the AP and controller.
Carson Hulcher, ACEX#110
Original Message:
Sent: Oct 07, 2023 01:38 AM
Currently were are deploy Aruba 7010 standaalone controller with 17 Aruba 505. Controller uplink to Core Switch using LACP 2Gb port. The SSID using tunnel mode uisng wpa2. The internet speed is 1GB. When we do speed test or ipert we only can get around 400mbps speed for upload and down. If we change the ssid to bridge mode tje speedtest or iperf we can get 600mbps. Also we already try enabke drop multicast also same. Is this limited for tunnel mode? We also already try with decrypt-tunel the speed also same around 400mbps. Is it any tunnel feature that can cause this different?. Is there away to improve wifi speed in tunnnel mode.? Or is this beacuse of controller 7010? Current firmware version is 8.10.0.7.
