  • 1.  SSID using only 2.4G band not function well at some AP
    Posted Feb 07, 2025 03:01 AM
    Product: IAP555
    Background: I created a hidden SSID namely "INF5-PSK" which only using 2.4G band only and this SSID were provisioning at all APs.  I found that some of the APs can using this hidden SSID but some do not.  What is the possible reason?  Thanks.
    The DHCP is handled by Forti firewall and the switches configuration for all ports which connecting to the APs are the same.
    Attached the configuration of IAP
    Attachment(s)
    txt
    backup-20250204-HPE.txt   7 KB 1 version
  • 2.  RE: SSID using only 2.4G band not function well at some AP
    Posted Feb 07, 2025 10:37 AM
    Update the software to something currently supported, you're still running the original release of 8.7.1.
    How have you determined that the WLAN is working for some APs but not others?
    Carson Hulcher, ACEX#110
  • 3.  RE: SSID using only 2.4G band not function well at some AP
    Posted Feb 09, 2025 11:21 PM
    There are total 10 * APs deployed in the office.  Some of APs can surf on the internet by connecting the said hidden SSID using laptop and/or mobile device but some do not.  As there is no zone number is configured to that hidden SSID profile, so i believe this SSID were provisioned to all APs.
    Yup.  The firmware version of all APs are still stick into original release,  May I know what is the stable version and provide the upgrade path or procedure of firmware upgrade? Thank you.
  • 4.  RE: SSID using only 2.4G band not function well at some AP
    Posted Feb 10, 2025 02:46 AM
    Hi Billy.
    Not much info in your post. No AP models at least.
    Assuming that you have APs in Aruba Instant mode.
    This simptom is sometimes observed when you don't have all needed vlans configured on the switches for all APs.
    First check that all required vlans are tagged/untagged on all APs. Then depend on your AP model check release notes for latest version.  You can check if upgrade version exist for your configuration on Maintenance / Check for New Version
    From here you can upgrade your APs. If you are in Instant mode DO NOT UPGRADE TO V10.* !!! Check release notes before upgrading. Not all AP models are supported in latest versions. Version 8.10 is safe bet for most AP models.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 5.  RE: SSID using only 2.4G band not function well at some AP
    Posted Feb 10, 2025 02:58 AM
    Not much info in your post. No AP models at least.  IAP555
    Assuming that you have APs in Aruba Instant mode. Yes, one of the AP act as virtual controller
    This simptom is sometimes observed when you don't have all needed vlans configured on the switches for all APs. As mentioned, all switches configure that connecting to the APs are the same.
    From here you can upgrade your APs. If you are in Instant mode DO NOT UPGRADE TO V10.* !!! Check release notes before upgrading. Not all AP models are supported in latest versions. Version 8.10 is safe bet for most AP models.  Thanks for your valuable information.
  • 6.  RE: SSID using only 2.4G band not function well at some AP
    Posted Feb 10, 2025 12:31 PM
    Edited by Lord Feb 10, 2025 12:33 PM
    Check whether all APs are broadcasting this SSID. Go to the Support menu in the GUI, enter "AP BSSID Table" in the Command field and select "All Access Points" in the Target field.
    Check whether the clients cannot associate with the WLAN at all, or whether only IP communication is not working. Go to Dashboard/Clients in the GUI. Are problem clients displayed there? If so, what is shown in the IP Address column?
    As @Gorazd mentioned, your symptoms occur when the Access VLAN is not tagged on the switch port. Double check that the VLAN 19 is correctly tagged on the access ports and uplinks.
    Waldemar
    ACCX # 1377, ACEP, ACX - Network Security
  • 7.  RE: SSID using only 2.4G band not function well at some AP
    Posted Feb 11, 2025 01:56 AM
    @Gorazd, @lord.
    It is my fault, i double check the permitted vlan in switches side, i discovered the vlan 19 is missing and the SSID is working after added the required vlan in switches side, thanks all.
  • 8.  RE: SSID using only 2.4G band not function well at some AP
    Posted Feb 11, 2025 02:20 AM
    Hi Billy.
    Glad that you found the problem in vlan settings. Been in this hole many times just to discover that vlan is not propagated properly somewhere in the network.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
