SSID with tunnel mode in AOS 10 is just in surviving state or connecting
  • 1.  SSID with tunnel mode in AOS 10 is just in surviving state or connecting
    Posted Nov 05, 2024 06:20 AM
    I have 2 APs 515 that have AOS version 10.7.0.1 and a Gateway 9012 with AOS 10.7.0.1, these devices are in the same network segment so they have connectivity between them.
    I have created a ssid in tunnel mode but checking the status of the tunnel from any of the APs, it only alternates between surviving and connecting states.  I can't figure out why the tunnel can't be established, do you have any suggestions?
  • 2.  RE: SSID with tunnel mode in AOS 10 is just in surviving state or connecting
    Posted Nov 05, 2024 06:22 AM
    It looks like the AP cannot reach the gateway (on it's system IP). If the AP and gateway are in the same network segment, make sure the system IP is set to that VLAN, or that routing from the AP to the system IP is working properly.
