Network Management
SSL certificate installation on AirWave 8.2.11+
This thread has been viewed 61 times
  • 1.  SSL certificate installation on AirWave 8.2.11+
    Posted Jun 16, 2021 04:44 PM
    Introduction
    This document contains technical elements (not exhaustive) to take into account when installing a server SSL certificate on AirWave 8.2.11
    The method used in the document is based on creating the .cer file and the .pfx file from OpenSSL and the Microsoft certificate authority installed on a Windows server 2019.
    Prerequisites used in the example below:
    • Aruba AirWave 8.2.12
    • Serveur PKI Microsoft server 2019
    • OpenSSL LibreSSL 2.8.3
    The AirWave hostname used for the certificate will be Airwavelab
    PREPARATION OF CERTIFICATE ELEMENTS
    Generation of .csr file and private key
    From the PC where OpenSSL is installed, create an AirWave_Cert target directory, from the terminal enter the following command:
    openssl req -utf8 -nodes -sha256 -newkey rsa:2048 -keyout airwavelab.key -out airwavelab.csr
    airwavelab.key ==> Private Key
    airwavelab.csr ==> Certificate Request File
    Generate .cer file
    Open the airwavelab.csr file with the cat command and copy / paste the lines between -----BEGIN CERTIFICATE REQUEST ----- et -----END CERTIFICATE REQUEST-----
    Open the page https: // example / certsvr in the browser of the PKI server and click on Request a certificate
    Choose Submit an advanced certificate request (to be adapted according to your PKI server)
    Click on Create and submit a request to this CA
    Paste the result of the cat command and choose WebServer Template et click on Submit
    Download the certificate in base 64 encoded format
    Creating the .pfx file
    Pfx file generation
    To create the .pfx file, you must concatenate the private key, the .cer file and the ROOT-CA.cer certificate via the following command
    Airwavelab_cert openssl pkcs12 -export -out airwavelab.pfx -inkey airwavelab.key -in airwavelab.cer -certfile culetto-CA.cer
    SSL CERTIFICATE INSTALLATION
    Transfer .pfx file to AirWave
    I am using a Linux bounce web server for the scp, it is possible to perform the operation directly from your PC.
    From the ssh connection on the AirWave, connect with the ampadmin account and follow the instructions on the screen
    The 1st step is to load the certificate in the AirWave ==>  Select 1 Files
    Select 1 to import the .pfx certificate using the scp command
    SCP Source (user@host:path): adminloc@10.224.110.20:cert_temp/airwavelab.pfx
     Select b to return to the home screen for further operations
    Import certificat SSL et installation
    Once the certificate is available in AirWave, the declaration is made in Select 3 Configuration
    Select 4 Certificate
    Select 1 Add SSL Certificate
    The previously loaded certificate appears in the list
    Enter the password defined when creating the .pfx file
    The certificate is now installed and the secure connection in https
    Deletion of expired certificate
    From the main menu, it is possible to clean up old expired certificates
    Select 1 Files ==> 3 Delete file
     French version is available here ==> Forum Français
    Nicolas Culetto
    SE Aruba France
