We got a few clientes which dont want this ssl error
I was reading this
https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-replace-Captive-Portal-SSL-certificate-and-get-NO-invalid/ta-p/179946
It says that we need to use linux to generate CSR Request
But what happens if we Generate it with the controller
IS there any difference????
Also
If i put it to use HTTP instead of HTTPS i guess ill get rid of the error. But then that would be insecure right? as user and pass will be on clearpatext?
Any thoughs on this last one?
Cheers
Carlos
