Aruba Controller(7010)のOSを8.7.1.9に更新したところ、以下のようなログが大量に出力されるようになりました。
(Aruba) *[mm] #show log system all
Apr 22 10:35:42 httpd[7125]: <350005> <7155> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:810526940
Apr 22 10:35:42 httpd[7125]: <350005> <7156> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:812624092
Apr 22 10:35:42 httpd[7125]: <350005> <7157> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:814721244
Apr 22 10:35:42 httpd[7125]: <350005> <7158> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:816818396
Apr 22 10:35:42 httpd[7125]: <350005> <7159> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:818915548
Apr 22 10:35:42 httpd[7125]: <350005> <7161> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:823109852
Apr 22 10:35:42 httpd[7125]: <350005> <7160> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:821012700
Apr 22 10:35:42 httpd[7125]: <350005> <7162> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:825207004
Apr 22 10:35:42 httpd[7125]: <350005> <7163> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:827304156
Apr 22 10:35:42 httpd[7125]: <350005> <7164> <DBUG> |httpd| |webserver| [ssl_engine_log.c:127] SSL Library Error: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown (SSL alert number 46) error code:829401308
Apr 22 10:35:42 httpd[7125]: <350010> <7165> <DBUG> |httpd| |webserver| [mod_aruba_auth.c:1562] Received request for CSRF token
Apr 22 10:35:42 httpd[7125]: <350010> <7166> <DBUG> |httpd| |webserver| [mod_aruba_auth.c:1562] Received request for CSRF token
Apr 22 10:35:42 httpd[7125]: <350010> <7167> <DBUG> |httpd| |webserver| [mod_aruba_auth.c:1562] Received request for CSRF token
Apr 22 10:35:42 httpd[7125]: <350010> <7168> <DBUG> |httpd| |webserver| [mod_aruba_auth.c:1562] Received request for CSRF token
Apr 22 10:35:42 httpd[7125]: <350010> <7169> <DBUG> |httpd| |webserver| [mod_aruba_auth.c:1562] Received request for CSRF token
Apr 22 10:35:42 httpd[7125]: <350010> <7170> <DBUG> |httpd| |webserver| [mod_aruba_auth.c:1562] Received request for CSRF token
ログ設定は以下のとおりです。
また、WebアクセスにChromeとEdgeどちらを使用しても変化ありませんでした。
このログ出力を止めるにはどのような設定が必要でしょうか。
(Aruba) *[mm] #show logging level
LOGGING LEVELS
Facility Level
arm warnings
network warnings
security warnings
system warnings
user warnings
wireless warnings
(Aruba) *[mm] #show debug
DEBUG LEVELS
Facility Level Debug Value Sub Category Process
(Aruba) *[mm] #
