the core switch is 5406 with 24 MiniGBIC module and 24 10/100/1000M module.
stack group 1 to group 8 are composed by 2824 or 2626 PWR.
5406 use 2 fiber to each stack group.
"trunk a1,a2 trk1 lacp
trunk a3,a4 trk2 lacp
and in stack group.
fist uplink port and the last switch uplink port:
"interface 24
lacp enable"
Q1: does this trunk type between stack group is suitable ?
Q2: From group 1 to 6, itâ s ok.both fiber led is light. But group 7 and 8 , the trunk fiber led only one light. Why ?
i have check the ProCurve_Switch_5400zl_Series_Reviewers_Guide ,does this issue cause by "28.8 Gbps backplane interface per Line Interface Module " ?
Thank you in advance. please check the attached layout .
ray ma
