Comware
  • 1.  stacking H3C S5500-EI
    Posted Aug 10, 2011 05:09 AM
    I have two H3C S5500-EI switches and i'm trying to stack them.
    Is this possible to do and where might i find the commands?
    product number is JD3778
  • 2.  RE: stacking H3C S5500-EI
    Posted Aug 10, 2011 05:59 AM
    The function for stacking in H3C is called IRF. Look up the command line reference for IRF chapter.
    You'll also need a 10GbE module in each switch.
    This is a great start: http://www.h3c.com/portal/download.do?id=1026568
