Comware
  • 1.  Stacking JG240A HP A5500 48G-PoE+ EI with H3C S5500-52C-PWR-EI
    Posted Nov 09, 2012 06:40 AM
    Hi All,
    As HP has renamed the H3C S5500-52C-PWR-EI into  JG240A HP A5500 48G-PoE+ EI, can someone tell me if the two are stackable? I already have 3x of the old H3C S5500-52C-PWR-EI in a stack but due to expansion the team have just procured a  JG240A HP A5500 48G-PoE+ EI switch to also be stacked. Is it possible to introduce the new HP A5500 switch into the stack?
    The stack is done by CX4 modules.
    Jazz
  • 2.  RE: Stacking JG240A HP A5500 48G-PoE+ EI with H3C S5500-52C-PWR-EI
    Posted Nov 09, 2012 12:25 PM
    It's the same hardware just renamed so I can't see why it wouldnt work. You'll probably need to upgrade the current stack to a new HP branded software though, since that will probably be whats on the new 5500.
  • 3.  RE: Stacking JG240A HP A5500 48G-PoE+ EI with H3C S5500-52C-PWR-EI
    Posted Nov 09, 2012 04:14 PM
    Hi Jazz,
    If you take a look at the release notes for the latest code, there's a command in there to set the branding of the switches. I don't remember the exact details, but it seemed fairly straightforward when i was reading them. If i remember correctly, the brand must be set to the same thing on all stack members.
