i recently migrated my Aos6 Master - Standby Master ,to AOS8 standalone MCs.
when i connect to my Master controller, i can change the configuration either by clicking on "CTRL-WIFI-MST-NODAL" which is the Master, or i can change config by clicking on "Mobility Controller" menu.
but if i do so, all changes i do are not synced with the MC.
Basically it only works if i change at "CTRL-WIFI-MST-NODAL" level. Whats the point of this Mobility controller menu then?
