Wired Intelligent Edge
Static ARP entry
Jerome Covini
Jerome CoviniMar 18, 2008 04:15 AM
  • 1.  Static ARP entry
    Posted Mar 17, 2008 09:14 AM
    How can I create a static ARP entry on a Procurve Switch like the 5412/8212 ?
    What is the command, I can't find it ?!
    P.S. This thread has been moved from Switches, Hubs, Modems (Legacy ITRC forum) to ProCurve / ProVision-Based. - Hp Forum Moderator
  • 2.  RE: Static ARP entry
    Posted Mar 17, 2008 10:37 AM
    To associate a MAC address with a port, use the "port-security" command.
    To associate an IP address and MAC address, use the "ip source-binding" command.
    casevh
  • 3.  RE: Static ARP entry
    Posted Mar 17, 2008 10:46 AM
    Hi
    I think DHCP Snooping must be enabled to have this binding between ARP and MAC result from :
    ip source-binding
    Good Luck !!!
  • 4.  RE: Static ARP entry
    >To associate an IP address and MAC address, >use the "ip source-binding" command.
    That's for the DHCP snooping database isn't it ?!?!
    I need to create a static ARP entry in the ARP table, not in the DHCP snooping database. I am not using DHCP snooping.
  • 5.  RE: Static ARP entry
    Posted Mar 17, 2008 07:06 PM
    Static ARP is not an option on these switches. You can increase the ARP age and mac-age timers but that's about it.
    Why exactly do you need to create a static ARP entry? Maybe there is some other solution?
  • 6.  RE: Static ARP entry
    Posted Mar 18, 2008 04:15 AM
    Hi Matt,
    I need it for MS NLB Multicast.
  • 7.  RE: Static ARP entry
    Posted Mar 18, 2008 03:54 PM
    Without the static ARP entry, does it work at all? I just want to confirm if it does not work, or if you're trying to limit the flooding due to the multicast-mac not being installed in the ARP table.
  • 8.  RE: Static ARP entry
    Posted Mar 19, 2008 03:09 AM
    The problem is not the L2 flooding.
    What does a router when it receives packet for a directly connected subnet, and if the target host is not found into ARP table ? It ARPs for it.
    Problem, ARP protocol is not designed to deal with multicast macs, only unicast mac. By essence, multicast uses GARP / GMRP instead.
    RFC 1812 : "... A router MUST not believe any ARP reply that claims that the Link Layer address of another host or router is a broadcast or multicast address...". That's what the procurve will purposedly do, hence the need for a static ARP entry when using NLB Multicast.
  • 9.  RE: Static ARP entry
    Posted Mar 19, 2008 05:03 PM
    I think you're out of luck for the time being and you'll probably have to use Unicast mode or a different router. It seems like Static ARP would be a feature we'd have seen by now. I would recommend you contact your ProCurve sales rep to see if they can push for this feature to be added.
  • 10.  RE: Static ARP entry
    Posted Feb 17, 2010 06:54 AM
    We have encountered the exact same problem; that this enterprise-level switch doesnt allow you to add a static ARP Entry.
    It's just not good enough.
    That's the last time we use a HP switch (it's now caused us all sorts of problems regarding our customer requiring MS NLB to load balance their web servers).
    Not happy at all.
    WittZi.
  • 11.  RE: Static ARP entry
    Posted Dec 22, 2010 08:48 AM
    I need also a static ARP entry for MS-NLB on a ProCurve 5400. Is static ARP in the newest Software revision implement?
  • 12.  RE: Static ARP entry
    Posted Dec 27, 2010 09:40 AM
    Hi Jerome,
    on latest OS images K15.02.xx or K.14.55.xx and above:
    ip arp-mcast-replies
    You cannot create a static arp entry like on cisco gears but the switch will handle the mcast mac address as ip multicast.
    *Note*: we are *still* talking about per RFC1112 (01:00:xx..)mcast addresses and not Microsoft "creative" ones (03:BF:xx..) and so yes you have to use NLB/IGMP mode.
    Antonio
  • 13.  RE: Static ARP entry
    Posted Jan 27, 2012 12:55 PM
    I too need to possibly add a static ARP on a 3500yl switch with the Premium license.  Can someone explain to me how ip arp-mcast-replies works and if it is a substitution for adding a static ARP entry when used with IGMP and Microsoft NLB multicasting - IGMP mode.
    Thanks.
  • 14.  RE: Static ARP entry
    Posted Jan 21, 2014 11:16 AM
    Anyone know what the arp entry limit is on a 3500yl?
  • 15.  RE: Static ARP entry
    Posted Dec 28, 2010 09:56 AM
    And for Microsoft "creative" version?
    Anyone has experience with ex 3Com-H3C?
  • 16.  RE: Static ARP entry
    Posted Jan 03, 2011 09:44 AM
    Hi Mauro,
    as Matt say you are out of luck because the switch will not save an ARP entry since you have a multicast MAC (03:BF:xx) BUT an unicast IP (cluster VIP).
    H3C gears have static MAC/ARP support in unicast and musticast mode.
    We plan to use H3C hardware on some customers when they will upgrade core facility since are more competitive on cisco (well sort of=) "datacenter" advanced features (IRF to name one..and no i dont like procurve DLACP limitations).
    Antonio
  • 17.  RE: Static ARP entry
    Posted Jan 30, 2011 08:19 AM
    i confirm that on a 5400 zl the ip arp-mcast-replies works for K.15.02.0005 and i wold like to thank everyone: you have just saves my week ( maybe month )
  • 18.  RE: Static ARP entry
    Posted Apr 12, 2011 01:04 AM
    i also confirm K15.03.0007 adds the ip arp-mcast-replies to the 8212zl switch.
    Using WNLB you must enable IGMP on the switch and configure the NLB cluster in Muiticast with IGPM.
    Wait for the ARP table to update - depends on the aging set on your switch and all is good.
  • 19.  RE: Static ARP entry
    Posted Nov 17, 2011 05:52 AM
    Hi All,
    I need one clarification on same topic. Here we have Procurve 8212 core switch, Procurve 6600 as Distribution Switches and Procurve 5412 access swtiches. My servers are connected to Procurve 5412. Please let me know one which switch I need to apply the below command to enable the NLB.
    ProCurve(config)# ip arp-mcast-replies
    Regads,
    Siva
