static host list (wireless IoTs not 802.1x capable) for the guest wifi - is it possible?
  • 1.  static host list (wireless IoTs not 802.1x capable) for the guest wifi - is it possible?
    Posted Oct 01, 2024 04:06 PM
    We have both Clearpass and MobilityMaster and have wireless IoT devices that need to be connected. Can these devices be automatically authenticated thru static host list, by passing the guest portal?
    Please advise
  • 2.  RE: static host list (wireless IoTs not 802.1x capable) for the guest wifi - is it possible?
    Posted Oct 01, 2024 04:55 PM
    Would not recommend using a static host list.  Utilize device registration to get the devices into the [Guest Device Repository] and then use that as the source for bypassing the captive portal.
    Carson Hulcher, ACEX#110
  • 3.  RE: static host list (wireless IoTs not 802.1x capable) for the guest wifi - is it possible?
    Posted Oct 02, 2024 11:38 AM
    Yup this^ Static Hosts List are a legacy feature and should no longer be used.
    I would also suggest using MPSK with Profiling for this IOT use-case vs static MAC registration: https://www.adamhollifield.com/2022/09/clearpass-mpsk-per-device-type-with.html
