I have two Aruba 2930F configured as Core switches with VRRP.
One the master I'm able to add a static route 0.0.0.0 0.0.0.0 10.15.101.251 and it is shown with the command "sh ip route".
On the backup I have the same configuration but when i add the static route 0.0.0.0 0.0.0.0 10.15.101.251 it is saved in the configuration but it will not be shown with the command "sh ip route"
Also when i try to ping an ip address from backup to master, for example vlan 25 (x.x.x.254) i got the message "destination not reachable".
It looks like if the backup don't have a default gateway or route to the master.
Between the master a lacp trunk is created, with all vlan's tagged.
Does anyone has a solution to this problem?
