I'm going to deploy a fiber ring to a new building, and I'm thinking of that setup:
V1910-24G-POE V1910-24G-POE
E2910-24G + 4 FO gbic
V1910-24G-POE-----------------V1910-24G-POE
As you can see 2 V1910 are going to be on a loop, so I think I need to setup stp for this to work.
Do you think it's going to be ok to mix "real" procurve with "3com" procurve? Or am I going to have problems with stp/vlans?
Another option would be to replace the V1910 with 2610-24G-POE + gbics, (a bit more expensive) what do you think?
